Guest mick_borthwick Posted September 28, 2007 Share Posted September 28, 2007 Hia all. Ive just brought a new weather seal that goes around the back lower part of the hood from ford (costing £49)!. Its the one that the toureu cover pops onto, and I had tried to fit and im still facing the same problem as when the roof raises it pulls the seal from the body.. Its seems like there should be some adisive on there or something, so was woundering if anyone knew what I should use. cheers mick Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted September 28, 2007 Share Posted September 28, 2007 pass cant help you but my mk6 has the same problem ... to be honest i havent really looked into it or the problem lol Link to comment Share on other sites More sharing options...
Guest mick_borthwick Posted October 4, 2007 Share Posted October 4, 2007 Hia, Hopefully Ive got this problem sorted out now..phoned my local hood fitter and he said to make sure that the seal overlaps the body at the bottom as there is a resess there as well.. Also I was told to add some industrial strength super glue around the body and hopefully this has done the trick now.. mick Link to comment Share on other sites More sharing options...
Admin Ollie Posted October 5, 2007 Admin Share Posted October 5, 2007 Hia, Hopefully Ive got this problem sorted out now..phoned my local hood fitter and he said to make sure that the seal overlaps the body at the bottom as there is a resess there as well.. Also I was told to add some industrial strength super glue around the body and hopefully this has done the trick now.. mick hi mick hope you have sorted it m8 yeah i had the same problem on the mrk5 blue one too and there is a lip on the inside that the rubber sits and holds on to although the rust had got to it on the drivers side lol and was not there cheers ollie Link to comment Share on other sites More sharing options...
Guest mick_borthwick Posted October 5, 2007 Share Posted October 5, 2007 Yea mate, seems to be sorted out now and staying down..as for the rust part its exactly same on mine, but the passenger side..so I put alot of super glue around that area and its worked.. Link to comment Share on other sites More sharing options...
