Guest Fordstevie77 Posted November 20, 2015 Share Posted November 20, 2015 What is the job of the ignition module amplier....? The black box with 2 screws holding it on the Distributor housing with 3 wires going to it.... 1 x black ignition live 1x brown earth 1 x green from ignition coil So what is the job of this amplifier/module as i see tell sell NEW aftermarket ones now so must be important and break often... Lol ebay number http://www.ebay.co.uk/itm/310854485535?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted November 20, 2015 Share Posted November 20, 2015 Not too sure exactly what it does but I know when mine died on my mk2 fiesta I had no spark lol Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted November 20, 2015 Admin Share Posted November 20, 2015 In a nut shell During the engine cranking , on Jetronic management the amplifier receives pulse signal from the distributor via magnetic pick up coil , or from the crank angle sensor and ECU on later Motronic management and uses this signal to open and close the ignition coil ground circuit , in order to fire up the spark plugs REGARDS OLLIE Quote Link to comment Share on other sites More sharing options...
Paul Grainger Posted June 19, 2016 Share Posted June 19, 2016 The pick ups in the distributor create just small signals which are not capable of switching the primary ignition coil. The amplifier uses these signals to decide when to do the coil switching. When they switch off the primary coil then a voltage is created in the second winding in the coil, this is the one which gives you the spark at the plugs. Hope this helps. Quote Link to comment Share on other sites More sharing options...
