Good Old Leaks!
Guest mr grady
Guest mr grady
sorry if this is a common thread, but im getting very peeved with my car becoming a swimming pool.
all the water collects in the rear passenger foot area.
the roof does not have any tears or holes, but if i lower it just after some rain, there is water in the metal framework of the roof. this pours out when the roof is up and i pull away, soaking who ever is in the front seats....drivers side is worse.
any advice or suggestions?
thanks for taking time to read this.
Guest mr grady
As pip said mate never came across this on the forum
hopes someone can offer some advice.
next few days im going to try sitting in it, and have a mate use the hose on the car and try to see where its coming in............
or just sit in it........as the weather is so bad!!!
  • 3 weeks later...
Same prob right here, got water about an inch deep in the back footwells. Carpets gone green :ohmy:( Wanna try and get it back on the road asap and dont want it wet and smelly!! I suspect its the seals on the passenger side, anyone know where you can get them?
Dave
I have the same problem with my Mk5a, if you have the same cab then listen up, I recon its the old favorite, the battery tray, plus, on the passenger door at the bottom you will see the join in the rubber seals, I think it might drip through there !!!
But look on the bright side, the rear foot well is always clean, and rear passengers can wash there feet lol !!!! :biggrin:
Guest diane
Yeah I have the same problem in mine . I think mine is the battery tray havent got round to looking at it yet , if it rains i cover her up lol .
Yeah built in foot spa !
Guest 6tracy9
Mine does it on the drivers side rear foot well!!!
Defo not the battery tray - but think it may be the rubbers at the bottom of the door!
Luckily I have not come across this problem. I can only advise to check the battery tray area. Clean the sill drain holes out with the mud that clogs them up. remove the front plastic inner wheelarch liners then clean the mud that gets stored behind it at the bottom. Next other thing it to put some sealant at the top of the door frame rubbers.
