Skittles80 Posted May 17, 2016 Share Posted May 17, 2016 At one of the shows I recall some one saying you can fit an up rated starter from a later ford to get rid of the issues with the current starters from meomry I think some one said people are fitting transit connect starters to mk4 escorts is there any similar mods for the mk5 escort zetec thanx mark Quote Link to comment Share on other sites More sharing options...
Vincygav Posted May 18, 2016 Share Posted May 18, 2016 Only thing I know some people fitted the diesel Escort starter motor. It is bigger in size and would be a tight fit, but it fits. What is wrong with the standard starter. At one of the shows I recall some one saying you can fit an up rated starter from a later ford to get rid of the issues with the current starters from meomry I think some one said people are fitting transit connect starters to mk4 escorts is there any similar mods for the mk5 escort zetec thanx mark Quote Link to comment Share on other sites More sharing options...
Skittles80 Posted May 18, 2016 Author Share Posted May 18, 2016 Been told they get hot and dry out starts fine then randomly after a run refuses to start again Quote Link to comment Share on other sites More sharing options...
Guest username Posted May 19, 2016 Share Posted May 19, 2016 Ours does suffer randomly with heatsoak but it's only ever cranked slowly, never refused to start Been thinking about dripping a bit of oil into the starter's bearings as I saw how much faster an old inertia motor spun when the bearings were oiled and it was the difference in that case between buying a recon starter and it starting a rebuilt engine with ease. Also make sure all the heavy wiring is in good shape and the terminals are clean and tight including the engine earths, had a 205D that used to need the gearbox earth bolt whacking with a hammer when hot, till I took it off and cleaned it... Quote Link to comment Share on other sites More sharing options...
Vincygav Posted May 20, 2016 Share Posted May 20, 2016 Also check the switched live wire from the fusebox to the starter motor, the whole thing. Mine played up and replaced two starter motors thinkgins it wasn't good as as always getting hot start problems where the starter wouldn't turn, even changed battery twice because of it. Over the years they tend to create more resistance, worse when hot. Quote Link to comment Share on other sites More sharing options...
