Guest Ben Calverley Posted March 9, 2016 Share Posted March 9, 2016 Water gettin into passenger foot well from under dash not from hood???????? Need a gas strut for boot Need a drivers side wiper nut cover Quote Link to comment Share on other sites More sharing options...
Guest John Posted March 9, 2016 Share Posted March 9, 2016 check under battery tray Quote Link to comment Share on other sites More sharing options...
Guest Ben Calverley Posted March 10, 2016 Share Posted March 10, 2016 Will do thanks Quote Link to comment Share on other sites More sharing options...
Ian71 Posted March 10, 2016 Share Posted March 10, 2016 Is the water from the outside or if it smells a bit,might be heater rad or hoses leaking ? Quote Link to comment Share on other sites More sharing options...
Guest Ben Calverley Posted March 11, 2016 Share Posted March 11, 2016 Cooling and heating system is ok just had it looked at. Quote Link to comment Share on other sites More sharing options...
welshlad Posted March 11, 2016 Share Posted March 11, 2016 Id agree with john def check the battery tray, possibly even remove the dash and check under were the bat tray is but inside the car as you might not see much under the bat itself. On mine the water leak was the heater matrix under the dash cheap to buy but a pain in the arse to fit Quote Link to comment Share on other sites More sharing options...
