Guest DLWarrior Posted June 19, 2015 Share Posted June 19, 2015 Hi Wonder if anyone has come across same problems Mk 3 RST series 1 conversion Engine when idle seems to cut out when heater turned on. Also seems to run very hot head gasket all been done with new thermostat only seems to do it when sat idling for a while Thanks Quote Link to comment Share on other sites More sharing options...
Ian71 Posted June 19, 2015 Share Posted June 19, 2015 cvh engines do generally run hot when on tickover , is the fan cutting in ok and bringing the temp gauge down ? Quote Link to comment Share on other sites More sharing options...
Guest DLWarrior Posted June 19, 2015 Share Posted June 19, 2015 cvh engines do generally run hot when on tickover , is the fan cutting in ok and bringing the temp gauge down ? Hi yes im sure it is.... it also has a manual switch to turn it on and seems to bring it down.... a bit worried don't want to cook the engine.. also noticed I can here a ticking as if the indicator is on but not coming from around the dashboard area ... think this maybe a relay but unsure what and where Quote Link to comment Share on other sites More sharing options...
Ian71 Posted June 20, 2015 Share Posted June 20, 2015 Yea wise to have a manual switch, i have three cars running cvh engines and have a manual switch to override just in case. I fitted twin fans on my rs turbo wired one to switch and one to thermostat, if i get in traffic jams on hot day i switch manual switch on before the temp gauge gets to high. Quote Link to comment Share on other sites More sharing options...
