Rodney Posted March 24, 2015 Share Posted March 24, 2015 I can push my steering wheel up just enough to make a small knocking noise, movement is no more than about 3mm. Two garages have checked it out by part dismantling and say it is perfectly safe. They both say the only way they could correct it would be a complete new steering column! It doesn't move with normal use you need to push it up - I only noticed it when pulling myself up on the wheel trying reach something. Anyone else got this 'feature'? Quote Link to comment Share on other sites More sharing options...
RScab Posted March 24, 2015 Share Posted March 24, 2015 Do you have the adjustable steering column? Quote Link to comment Share on other sites More sharing options...
Rodney Posted March 24, 2015 Author Share Posted March 24, 2015 Yes I do, large pull down lever underneath. Quote Link to comment Share on other sites More sharing options...
RScab Posted March 24, 2015 Share Posted March 24, 2015 Just had a look on Microcat (Ford parts Software) shows a column bush but no part number - so may be all in 1 with the column duz show a tolerance ring tho sits @ the top of the column worth changing that first see if it solves the problem Quote Link to comment Share on other sites More sharing options...
Rodney Posted March 25, 2015 Author Share Posted March 25, 2015 Many thanks I'll put that to my garage. Quote Link to comment Share on other sites More sharing options...
Rodney Posted January 12, 2022 Author Share Posted January 12, 2022 I have a Mk6 with the same column and also have a small movement up wards and a very small movement pulling the steering wheel straight towards me. The MoT inspector says it will be a fail next year. Replacements are no longer available and buying a second hand one is a gamble - it could be just as bad once fitted! Are there specialist companies that will refurb them or are alternatives made. The car is 100% otherwise but I now have the prospect of scrapping it after owning it for 22 years. Quote Link to comment Share on other sites More sharing options...
