Guest welsh welder Posted July 18, 2014 Share Posted July 18, 2014 Hi I've have a Mk5 cabriolet on m reg the problem is then you lock the drivers door it lock the passengers door but when you unlock the door it only opens the divers door but if you pull the drives door Handel it will unlock the passengers door thanks Quote Link to comment Share on other sites More sharing options...
jont Posted July 18, 2014 Share Posted July 18, 2014 Hi welsh welder had simller problem I took off the drivers door panal and took out all the central locking modular out give all the conections a good clean then put it all back together when I took my central locking modular out it it was not in the right position it had moved over time and was not engaging the lock hope this helps let us know how you get on jont Quote Link to comment Share on other sites More sharing options...
Ian71 Posted July 19, 2014 Share Posted July 19, 2014 Had similar problem with my mk5 project,as jont says clean alot of the conections they tend to corrode a bit. Quote Link to comment Share on other sites More sharing options...
Guest welsh welder Posted July 19, 2014 Share Posted July 19, 2014 Thanks I'll have a go at cleaning them I've changed the central locking control box and the switch around the locking barrel on difreant Quote Link to comment Share on other sites More sharing options...
