Guest Madmannuk Posted May 13, 2014 Share Posted May 13, 2014 Hi whats the best hydrolic roof oil to use to top the resevoir up and is it easy to do. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted May 13, 2014 Admin Share Posted May 13, 2014 quotes taken from an earlier post need to bleed the system too all in the Haynes manual Go to your VW Dealer and ask for some Hydraulic fluid G004 000. Correct stuff is Ford part number 13841104 apparently this is the same for all year cabriolets hope this helps ollie Quote Link to comment Share on other sites More sharing options...
