Guest kenny stag Posted September 22, 2013 Share Posted September 22, 2013 Hi All My drivers door keeps catching on the roof in the window is fully up. I have a mark 4 cabro model. Does any one have any ideas on how to cure this. As it is driving me mad. Many thanks Ailsa Kenny's wife Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted September 22, 2013 Admin Share Posted September 22, 2013 hello do you mean the glass just catches on the top when you close the door ... if so if you take the door card off you will see a 10mm bolt that makes a small adjustment to raise or lower the glass . be carefull though as to much and the top rubber wont make the seal and you will get a wet but when out in the rain lol hope this helps Ollie Quote Link to comment Share on other sites More sharing options...
Guest Tony8020 Posted September 24, 2013 Share Posted September 24, 2013 Ailsa, this is a common problem unfortunately and whilst Ollie is spot on, to be honest you just learn to live with it and equally get very good at knowing where the glass needs to be when you raise the window. Also, try shutting the door whilst pressing the glass down a bit. At 1st it took me about 5 minutes to adjust each window but now it takes me seconds Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted September 30, 2013 Share Posted September 30, 2013 use to close my door by pushing top corner of the glass and it would always go under the rubber 1st time other than that it would stick on the rubber Quote Link to comment Share on other sites More sharing options...
Guest kenny stag Posted October 7, 2013 Share Posted October 7, 2013 Hi and many thanks for all your comments . Thanks Ailsa Quote Link to comment Share on other sites More sharing options...
Guest kenny stag Posted October 10, 2013 Share Posted October 10, 2013 Hi All sorted,many thanks for the replies. Ailsa Quote Link to comment Share on other sites More sharing options...
