Door Catching On The Roof
Guest kenny stag
Guest kenny stag
Hi All
My drivers door keeps catching on the roof in the window is fully up. I have a mark 4 cabro model. Does any one have any ideas on how to cure this. As it is driving me mad.
Many thanks
Ailsa
Kenny's wife
  • Admin
hello :biggrin:
do you mean the glass just catches on the top when you close the door ... if so if you take the door card off you will see a 10mm bolt that makes a small adjustment to raise or lower the glass .
be carefull though as to much and the top rubber wont make the seal and you will get a wet but when out in the rain lol
hope this helps
Ollie :smile:
Guest Tony8020
Ailsa, this is a common problem unfortunately and whilst Ollie is spot on, to be honest you just learn to live with it and equally get very good at knowing where the glass needs to be when you raise the window. Also, try shutting the door whilst pressing the glass down a bit. At 1st it took me about 5 minutes to adjust each window but now it takes me seconds
