Mk4 Electric Window Help
Guest Tony8020
Guest Tony8020
guys, help is required. the window doesn't go down all the way. I have investigated the cause and the motor and mechanism are fine. the runner on the side with the lock is the issue.
I have taken it
Guest Tony8020
stupid iPhone. try again
I have take the runner out and the window then goes all the way down but the runner is required as the window falls out without it.
I have tried adjusting the runner but just can make it work. does any one have a suggestion?
Guest Tony8020
I greased it all up and still no joy, the runner fits against the window perfectly when it's out of the car.
as it goes down the runner the runner buckles slightly and the motor stops, I can't see any other way of positioning it either
Guest Tony8020
yes seems to be, I noticed those screws in my Haynes manual but as I say, the window goes all the way down with the runner taken out so it must be the runner
You need to adjust the guides for the glass they are adjustable too. The hanynes manual doesn't tell you this.
There are four. Two on each side. If you move the guide out on the bottom this will stop it getting tight and it will go down
Guest Tony8020
ok mate I'll give that a go, it's strange how the runner twists slightly as the glass goes down. I'll get greasy again at the weekend and see what happens!
