welshlad Posted April 14, 2013 Share Posted April 14, 2013 just replaced wheel bearings and yes they are seated properly, problem is the hub is still loose and i cant tighten the nut anymore! any ideas? the seals are seated properly too! or should i just put another packing washer in there? Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted April 14, 2013 Admin Share Posted April 14, 2013 shouldn't have to put another washer in there to pack it out . take it you've done both side is the other one ok ? Quote Link to comment Share on other sites More sharing options...
welshlad Posted April 14, 2013 Author Share Posted April 14, 2013 yes the passenger side one is perfect, ive got the hub back off and it all looks fine it might be alright when i put it back on hopefully Quote Link to comment Share on other sites More sharing options...
welshlad Posted April 14, 2013 Author Share Posted April 14, 2013 Saying all this the rear seal isn't seated properly ffs and in the process of taking the new track control arm ball joint out of the hub I've split the seal grrrr gonna have to buy another new one in the morning at least its all done then apart from putting my new rear tie bars on the rear Quote Link to comment Share on other sites More sharing options...
