Guest Brundish Posted August 26, 2012 Share Posted August 26, 2012 Having a headache with this bloody warning light it always stays on. Tested the handbrake switch and that's fine checked and cleaned the brake fluid sensor and I think that's fine the only time it goes off is when I pull off the brake fluid sensor. Please help guys and girls as this is doing my head in and need it for the MOT. Quote Link to comment Share on other sites More sharing options...
RScab Posted August 26, 2012 Share Posted August 26, 2012 What year & model? m8 Quote Link to comment Share on other sites More sharing options...
Guest Brundish Posted August 27, 2012 Share Posted August 27, 2012 Yeah always forgetting that. Lol It's a mk4 cabriolet 1986 carb 1.6 Quote Link to comment Share on other sites More sharing options...
Guest rapiernut Posted August 28, 2012 Share Posted August 28, 2012 HI DID YOU CHEK YOUR FRONT BRAKE PADS BECOUSE SOME OF THEM HAVE WARE SENSORS ON THEM Quote Link to comment Share on other sites More sharing options...
Guest theprophet1978 Posted August 28, 2012 Share Posted August 28, 2012 doesnt have abs by chance does it? mine done the same till i realised the sensor switches had broken so wernt pushing on the belt Quote Link to comment Share on other sites More sharing options...
Guest Brundish Posted August 28, 2012 Share Posted August 28, 2012 Yeah it HAD abs at some point but some parts are gone and don't know what is missing. I've just bypass the thing and got a working handbrake warning light but no warning for brake fluid (but i can keep an eye on it.) can revert back if needed if I find out the problem. Quote Link to comment Share on other sites More sharing options...
Guest Brundish Posted August 28, 2012 Share Posted August 28, 2012 Doesn't have pad sensors on mine. Quote Link to comment Share on other sites More sharing options...
gingergman Posted August 30, 2012 Share Posted August 30, 2012 is this now needed for the MOT? i know it wasnt before but may have changed Quote Link to comment Share on other sites More sharing options...
Guest theprophet1978 Posted September 4, 2012 Share Posted September 4, 2012 from what i was told yes if the car has abs fitted and its not fully functional it will fail, i.e has the belts etc but no sensors...... but dont quote me on that Quote Link to comment Share on other sites More sharing options...
Guest xr3idan Posted November 10, 2012 Share Posted November 10, 2012 when mine went thru mot last week, it it had handbrake light and abs light on, failed for abs light but not handbrake light, i disconected sensor at brake fluid resivour, so as not to annoy me, sorted the abs light out n it went thru, so with that said im pretty sure the handbrake warning light dosent come into the mot, abs light however does.. Quote Link to comment Share on other sites More sharing options...
