Guest Donkeyx Posted June 14, 2012 Share Posted June 14, 2012 Hi guys, I'm new here, I have a white 1989 mk4 cabby, had her 9 yrs now full rs kit bonnet bumper etc recaros, lowered 60mm on 17"s that's about all really, gave her a full re paint in a strait including all shuts and new roof about 4yrs ago and she's only done about 2000 miles since, I have a silver top 2.0 Zetec removed from my old mondeo, I also have a set of bike carbs which I'm sending to Bogg brothers for a manifold and set up, I have the eddis management to get her up and running, my questions are, can I use a focus st 170 6 speed box with it and if so what clutch and flywheel combo will I need, also what other parts will I need ie engine mounts altinater, water pump (think there an issue also) sump or anything else I might not know about, hope you guys can help as I'm wanting to start on this as from next week. Quote Link to comment Share on other sites More sharing options...
badger Posted June 14, 2012 Share Posted June 14, 2012 hi mate i'm not sure on the gearbox but if you have the 2.0ltr zetec you will need to change the sump and strainer for an escort one and also the water pump as they run in the opposite direction you will need to modify the engine mount and use the origanal alternator mount from the cvh i have the rs turbo gearbox on with the lsd i i had to change the flywheel and clutch both to the escort one from a zetec it just makes things easy with the gearbox mountings and drive shafts etc etc. if you need any more info just give me a shout. badger Quote Link to comment Share on other sites More sharing options...
Guest Donkeyx Posted June 14, 2012 Share Posted June 14, 2012 Thanks for your reply, what doin get the water pump from? Quote Link to comment Share on other sites More sharing options...
badger Posted June 14, 2012 Share Posted June 14, 2012 Thanks for your reply, what doin get the water pump from? you can get one from a donnor car or fords or a pattern part but it must be from a zetec escort mk5 or 6 Quote Link to comment Share on other sites More sharing options...
Guest Smiler Posted June 14, 2012 Share Posted June 14, 2012 (edited) Have a look at my website: http://www.auto-tat....ades Index.html Select 'Engine' from the menu down the left hand side. Then 'Zetec' There are some page links at the bottom of that page that give clear details with photo's. Smiler. Edited June 14, 2012 by Smiler Quote Link to comment Share on other sites More sharing options...
Guest Donkeyx Posted June 15, 2012 Share Posted June 15, 2012 Just had a look, that's a great help thanks, will it still be the same clutch and flywheel for the 6 speed box? Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted June 15, 2012 Share Posted June 15, 2012 The flywheel and clutch is easy just use the st170 flywheel and clutch. Your biggest problem is getting the gearbox mounted. It requires chassis work to fabricate clearance and a new mounting position. Firms charge around £800 for that part of the work. Next problem is your going to have to convert the gearstick to a cable operated arrangment. Do able but again your going to have to strip the interior so access is there to weld and fabricate potensially using parts from a focus. Quote Link to comment Share on other sites More sharing options...
Guest Donkeyx Posted June 15, 2012 Share Posted June 15, 2012 Once again thanks gmfor the help guys, I can do the fab work my self so that's not a problem, do you know what has to be done to the chassis? Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted June 16, 2012 Share Posted June 16, 2012 I've heard the gearbox casing is larger so will foul on the left hand chassis leg. This will need a section removing / forming to go around the new gearbox. The mount itself is also in a different position to the ib5. So you'll need to form this in the right place. Your best offering the gearbox up removing the section of rail. Then offer it up to see where the new mount needs to be. Once you have that sussed it just a case of welding it all up. The gearstick setup just need form as per focus so i'd remove a section of metal with everything on from a focus and then offer it up to the escort and cut / weld as required Quote Link to comment Share on other sites More sharing options...
