Handling Problem Xr31 J Plate
Guest David Osik
Guest David Osik
WHEN I PUT FOOT DOWN IT VEERS TO RIGHT AND FEELS SOMETHING LOOSE HAD WISHBONES DONE WHAT ELSE COULD IT BE? ITS A MK 5
Guest Lee81
Tracking and loose bolts on the wishbones. They need to be prity tight or they will move around a fair few mm.
Failing that worn/damaged track rod ends
no that would give a steering wheel wobble, its the wishbones then if u say 1 is startin 2 rip, if ur confident wiv a spanner u can do the wishbones urself, but it is a bit harder on the floor sayin that if done it plenty of times & easier if u can use an impact gun, best tool i'v brought. still will need the trackin set up properly afterwards tho. dont buy cheap tho its false economy.
regards mark
