Guest dancabs Posted February 26, 2012 Share Posted February 26, 2012 My roof needs replacing and i have managed to find 1, the problem i have is mine is electric and the 1 i have found is manual. ARE THE FRAMES THE SAME AND WILL IT BOLT STRAIGHT ON AND WORK STRAIGHT AWAY OR WILL I HAVE TO MODIFY SOME THINGS. Cheers Dan Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted February 26, 2012 Share Posted February 26, 2012 They are the same just put your pins that your electric rams connect to on the frame from yours. Quote Link to comment Share on other sites More sharing options...
Guest dancabs Posted February 26, 2012 Share Posted February 26, 2012 Thought they was but wanted to double check. Thanks alot mate!! Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 26, 2012 Share Posted February 26, 2012 think they may be diffrent, manual have little knobs that stick out under the rear speaker pods, electric dont, think thats how it is, or it may just be a diffrent style frame, cant remember exactly the diffrences and why Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted February 26, 2012 Share Posted February 26, 2012 The hoods are the same just the ball joint need swaping so the rams connect to it. The hood locking knobs that gingergman is on about need to be taken off as there not required. if memory serves me right they are only held on by a Circlip. Quote Link to comment Share on other sites More sharing options...
Guest dancabs Posted March 1, 2012 Share Posted March 1, 2012 Thanks for the info. Got myself an electric replacement in the end anyway. Cheers tho Quote Link to comment Share on other sites More sharing options...
