maido Posted January 22, 2012 Share Posted January 22, 2012 hi im wanting to replace the bushes on my mk4 will xr3i/rs turbo ones fit or are they different because of the extra weight. Quote Link to comment Share on other sites More sharing options...
f40 cab Posted January 22, 2012 Share Posted January 22, 2012 what car is it engine etc, xr3i will fit turbo set up slightly different i think with regards to anti roll bar set up front and rear..you will need to check the front roll bar mounting bushes they did 2 sizes 22mm and 24mm but will say on the side of your old ones, i might stand corrected on all of this but hope it helps what bushes are you replacing them with? Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 22, 2012 Share Posted January 22, 2012 as f40 said, anti roll bar ones on a cab are 22mm and turbo i believe to be 24mm, so there diffrent, not sure on the rest though Quote Link to comment Share on other sites More sharing options...
f40 cab Posted January 22, 2012 Share Posted January 22, 2012 you will need to check whats on yours ive got the xr3i but it had 24mm, and ive bought second hand roll bar from same type car but 22mm so need to check whats on yours. Quote Link to comment Share on other sites More sharing options...
maido Posted January 22, 2012 Author Share Posted January 22, 2012 ok thanks for info ill have a look its got rs2000 engine in but suspension etc all standard Quote Link to comment Share on other sites More sharing options...
