Guest PhilKing Posted July 19, 2011 Share Posted July 19, 2011 Hi there Guys n Gals, I've bought a working Ford 2007 model radio cassette to help keep my car as original as poss, it was a straight plug in so I did but all that happens is the LCD display lights up (if the key is in or not), ive checked the fuse at the back of the unit an its fine but i must admit im hating having no radio working inn the car....Please help lol! Quote Link to comment Share on other sites More sharing options...
Guest Savage Posted July 19, 2011 Share Posted July 19, 2011 Did you have a stereo in there that worked before installing the new one? Quote Link to comment Share on other sites More sharing options...
allblue Posted July 19, 2011 Share Posted July 19, 2011 Is you car a mk4? How did you plug the speaker wires into the head unit? The 2007 radios fitted to mk4's do not have the amplifier circutry built in, that part is either in the seperate amp or graphic equaliser. You will also need the DIN cable that connects the two units together and the loom to power the amp/graphic. Quote Link to comment Share on other sites More sharing options...
Guest PhilKing Posted July 20, 2011 Share Posted July 20, 2011 I just plugged the 2 leads in the back and then the arial, but its not even powering up......but i only paid £1 for the radio so i havent lost anything, does anyone else have a standard Ford radio to sell? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted July 21, 2011 Share Posted July 21, 2011 (edited) If i remember the mk4 did not have 2007 radio it was the mk5 so the wire's maybe different???? The mk4 had 3 knobs on it not sure what it was called tho but deffo key coded Edited July 21, 2011 by shaun Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted July 22, 2011 Share Posted July 22, 2011 Sounds like your main power lead is not connected, just a secondary power which is optional. Or, thats why it only cost a pound lol Quote Link to comment Share on other sites More sharing options...
