New Springs
Guest derrick
Guest derrick
hi guys i just bought a set of 60mm gmax lowering springs for my 1991 cabbie and now need to get new shocks does anyone know where i can buy reasonable priced ones i need the full four shocks and what fitment do i need for a mk5 1.6 efi cabbie.
cheers
derrick
Guest s6boy1979
Be careful what shocks you get, i got a set of gmax shocks with 40mm springs. Gmax always come out lower than other makes i found and due to the extra weight of the cab i killed my front shocks in about a mounth. I have now ghot adjustable koni's and they are great as you can set them really soft for everyday driving which will stop tou killing them and makes the ride nicer but can be made hard if you fancy a bit of a blast.
Guest derrick
cheers mate ive had a look and there are loads of diffrent ones i was looking at bilsteina and koni so ill shop around money is a little tight so ill try and find some cheers again
