Guest col2010 Posted June 3, 2011 Share Posted June 3, 2011 (edited) any ideas my roof wont go down all the fuses are ok dont know were to start looking is an r reg escort 1.8 si Edited June 3, 2011 by col2010 Quote Link to comment Share on other sites More sharing options...
welshlad Posted June 3, 2011 Share Posted June 3, 2011 couold be realays if it isnt making a sound or the switch or if it is making a sound the pump that is then its the cog broken inside Quote Link to comment Share on other sites More sharing options...
Guest col2010 Posted June 3, 2011 Share Posted June 3, 2011 couold be realays if it isnt making a sound or the switch or if it is making a sound the pump that is then its the cog broken inside it's not making a sound...were do i look for the relays and how do i test them? Quote Link to comment Share on other sites More sharing options...
Basilbear Posted June 3, 2011 Share Posted June 3, 2011 it's not making a sound...were do i look for the relays and how do i test them? Have you done anything with your speaker pods? I changed mine nd thought the little wires attached to the back of them were earth wires....so I attched them to the car body...then my roof wouldn;t work at all! ha! It was only when someone said that they were not earth wires and their purpose was to connect to the tonneu cover poppers that it became apparent that when I earthed them that the roof wouldn't work because it alwys though the tonneau cover was attached! ha!. So maybe one of your wires has come loose and connected itself to the cr body! Only a thought if it turns out its not your relays or something else. Thanks Avril Quote Link to comment Share on other sites More sharing options...
Guest col2010 Posted June 4, 2011 Share Posted June 4, 2011 Have you done anything with your speaker pods? I changed mine nd thought the little wires attached to the back of them were earth wires....so I attched them to the car body...then my roof wouldn;t work at all! ha! It was only when someone said that they were not earth wires and their purpose was to connect to the tonneu cover poppers that it became apparent that when I earthed them that the roof wouldn't work because it alwys though the tonneau cover was attached! ha!. So maybe one of your wires has come loose and connected itself to the cr body! Only a thought if it turns out its not your relays or something else. Thanks Avril no not touched a thing i have found a big silver fuse near my pump someone said its prob that....just got to try and get one now....thank's for the reply Quote Link to comment Share on other sites More sharing options...
