Guest SharonO'brien Posted May 9, 2011 Share Posted May 9, 2011 Hi all..I have a 1989 cab Mark 4. It has efi engine..I've had new alternator, new battery and new earth strap.. He starts up ok, but when iv been out and stop the car n start it up again he won't start..although he will with a push, been told it maybe the timing..but not so sure myself...any thoughts..??? Quote Link to comment Share on other sites More sharing options...
gingergman Posted May 10, 2011 Share Posted May 10, 2011 sounds like the starter motor is getting too hot from heat off the exhaust, does it turn over very slow when hot? p.s off topic, thought you was selling it on ebay? i see it on there you see Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted May 10, 2011 Share Posted May 10, 2011 must be a common thing with mk4,s? mine does it too.another thing to fix on my list of things lol. Quote Link to comment Share on other sites More sharing options...
Guest SharonO'brien Posted May 10, 2011 Share Posted May 10, 2011 sounds like the starter motor is getting too hot from heat off the exhaust, does it turn over very slow when hot? p.s off topic, thought you was selling it on ebay? i see it on there you see [/quote Lol... I was indeed. I get dis-heartened with it. Then as soon as someone was coming to buy him I change my mind ( a woman's prerogative you know ). Now he's almost fixed.. In for his MOT on thursday. Then it's play time.. Hehehe. Quote Link to comment Share on other sites More sharing options...
Guest SharonO'brien Posted May 10, 2011 Share Posted May 10, 2011 must be a common thing with mk4,s? mine does it too.another thing to fix on my list of things lol. Well let me know what u come up with paul and I shall do the same. Lol Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted May 10, 2011 Share Posted May 10, 2011 (edited) There is a few options to get round this as i used to suffer badly with this on my old 1.4l as well as my rs turbo you can either heat wrap the down pipe or on the rs turbos there was a heat shield that was put on from std that would clip on to the down pipe to keep the heat off the back of the starter also. Heat wrap is probably the cheapest and easiest aswell as the more widly available option i'd say? Also try and clean the contacts up on the starter motor as every little helps as all your trying to combat is high resistance problems Edited May 10, 2011 by gavintwopies Quote Link to comment Share on other sites More sharing options...
Guest Alanman Posted May 10, 2011 Share Posted May 10, 2011 It might only be a short term fix but to free the starter a little take it off and clean it out with WD40. You'll notice a difference when it goes back on. Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted May 10, 2011 Share Posted May 10, 2011 Heard a few years ago that a diesel starter could be used, but dont know how true it is Quote Link to comment Share on other sites More sharing options...
Guest SharonO'brien Posted May 10, 2011 Share Posted May 10, 2011 Thanks guys...seems you r all saying it's the starter motor...so the timing sounds like it's ok then.. Quote Link to comment Share on other sites More sharing options...
Chris Posted May 11, 2011 Share Posted May 11, 2011 1.8 Zetec starters fit and work better as its shorter so it avoids the manifold and a huge battery.. the bigger amp the more clout the starters gonna get when it turns over Quote Link to comment Share on other sites More sharing options...
