Guest paul xr2 Posted January 30, 2011 Share Posted January 30, 2011 Thought i may as well start a thread on my cabs to show my progress on converting it from mfi to efi turbo This is how it was when i picked it up in march last year Then to this with a new roof different suspension and a set of 16inch oz super ts Damage to door and wing the previous did On my mates 8X16inch comp frs Parked up with my mates series1 turbo Typical escort battery tray Sat on 17inch wolfrace voodoos still sat on these now but i fancy a change Stg3 hybrid turbo Modded efi inlet and cross over Engine ready to come out and this is how it is now The engines sat in my mates shed but ill take more pics as i progress Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted January 30, 2011 Share Posted January 30, 2011 So i take it your just putting the engine loom in or are you going with a full loom swap? Also are you going to run OFAB or OFAC? Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted January 31, 2011 Share Posted January 31, 2011 So i take it your just putting the engine loom in or are you going with a full loom swap? Also are you going to run OFAB or OFAC? Ive got a complete efi xr3i loom and ofac ecu map sensor well everything really including an msd custom chip for my engine spec beige injectors also but stu told me theyll be running flat out lol Engines frst 1680cc accralite forged pistons arp bolts acl bearings brand new genuine oil pump and water pump done 0 miles Heads slightly polished and ported with a brand new standard cam lifters rockers and all nuts are new too Add to that a 3inch mongoose system the stg3 t3 airtec front mount cooler copper core rad and a monster grp a cossie k&n It should go pretty well i hope Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted February 1, 2011 Share Posted February 1, 2011 Forgot to add it runs standard compression 8.3.1 So as the weathers starting to warm up a bit i might spend a few hours on it over the weekend but i also need to fit the new coilovers on my daily driver focus and also fit the new rear brakes Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted February 1, 2011 Share Posted February 1, 2011 Keep the good work going Paul am sure you can get her on the road for the summer , You also forgot to say about your brake setup you have done Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted February 1, 2011 Share Posted February 1, 2011 Keep the good work going Paul am sure you can get her on the road for the summer , You also forgot to say about your brake setup you have done Ill get some pics of the brakes well the front ones not got round to fitting the rears yet lol ill have it on the road for may june at the latest Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted February 2, 2011 Share Posted February 2, 2011 Ill get some pics of the brakes well the front ones not got round to fitting the rears yet lol ill have it on the road for may june at the latest What set up you goingto be running like? Also with all that power you think the shell will do the engine justice with it not having the extra strength of a roof to keep it in check? Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted February 2, 2011 Share Posted February 2, 2011 What set up you goingto be running like? Also with all that power you think the shell will do the engine justice with it not having the extra strength of a roof to keep it in check? Nothing that special cossie 4wd calipers up front with black diamond 2wd cossie drilled & grooved discs and mintex 1144 pads and on the rear 2wd cossie calipers and black diamond drilled and grooved discs and 1144 mintex pads again so should stop pretty well not to worried about having to much power with no roof because its only for the summer and will be broke or sold about september time to fund a saff cossie Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted February 2, 2011 Share Posted February 2, 2011 Nothing that special cossie 4wd calipers up front with black diamond 2wd cossie drilled & grooved discs and mintex 1144 pads and on the rear 2wd cossie calipers and black diamond drilled and grooved discs and 1144 mintex pads again so should stop pretty well not to worried about having to much power with no roof because its only for the summer and will be broke or sold about september time to fund a saff cossie Now that sounds like a man with a plan......... hope it goes according to plan for ya keep the photos coming. Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted February 3, 2011 Share Posted February 3, 2011 Now that sounds like a man with a plan......... hope it goes according to plan for ya keep the photos coming. Thanks Gavin I bought one of your zvh water pump plates off you a couple weeks ago very good quality going to build a 1.8 zvh turbo for my mates mk2 orion 1.6i ghia Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted February 3, 2011 Share Posted February 3, 2011 (edited) Thanks Gavin I bought one of your zvh water pump plates off you a couple weeks ago very good quality going to build a 1.8 zvh turbo for my mates mk2 orion 1.6i ghia Good to hear, the 1.8 zvh is a good 1/2 way medium, i find you can have the bit extra grunt you want without making a massive dent in ya wallet if the car is a daily driver? As i made the massive mistake of taking mine out and putting in a 2.1 zvh i built!!!! massive difference over the 1.8 powerwise but my god did it drink the fuel. would only do around 125 to a full tank!! but the zvh would do about 200 to a tank. Do you use the 40mm core plug to blank the front breather or do you use a cover plate as i just got a few cover plates done but not in time to add them to the adaptor plate auction. Edited February 3, 2011 by gavintwopies Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted February 3, 2011 Share Posted February 3, 2011 Good to hear, the 1.8 zvh is a good 1/2 way medium, i find you can have the bit extra grunt you want without making a massive dent in ya wallet if the car is a daily driver? As i made the massive mistake of taking mine out and putting in a 2.1 zvh i built!!!! massive difference over the 1.8 powerwise but my god did it drink the fuel. would only do around 125 to a full tank!! but the zvh would do about 200 to a tank. Do you use the 40mm core plug to blank the front breather or do you use a cover plate as i just got a few cover plates done but not in time to add them to the adaptor plate auction. The orions only a weekend car so wont be to bad on fuel he hopes lol I used the core plug but im not really happy with it lol how much are the cover plates posted? Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted February 4, 2011 Share Posted February 4, 2011 The orions only a weekend car so wont be to bad on fuel he hopes lol I used the core plug but im not really happy with it lol how much are the cover plates posted? PM'D Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted March 6, 2011 Share Posted March 6, 2011 Time for a bit of an update Well i spent yesterday stripping the interior out so i could get to the underneath of the battery tray and to check the bulkhead for any major rust But what i found was that it was only the battery tray that needed doing Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted March 6, 2011 Share Posted March 6, 2011 Keep us posted with photos, as i too have to weld a battery tray in our birds motor too but i'm also going to hold off till the engine is out so i got somewhere to stand while i'm doing it...... any excuse for an engine out. Quote Link to comment Share on other sites More sharing options...
Guest Graham Posted March 6, 2011 Share Posted March 6, 2011 Good to see you are getting the car done Paul no wonder your car leaked that battery tray is a bit rotten Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 7, 2011 Share Posted March 7, 2011 wow, that is some bad rust!!! not good on the front cross member to. atleast the floor is soild, thats a brucie bonus Quote Link to comment Share on other sites More sharing options...
Guest paul xr2 Posted March 8, 2011 Share Posted March 8, 2011 Dont worry guys by the time ive welded the new battery tray in youll never know it was like this Ill cut the rot out the cross member before welding it too Quote Link to comment Share on other sites More sharing options...
