Guest dave29 Posted January 23, 2011 Share Posted January 23, 2011 hi all. while out and about in the cabby today id parked up to go to the shop and as i walked back to the car a noticed a small puddle of brown water under the car so i had a quick look under the car n it seams to be dripping from behind the bottom pully..........im guessing the water pump is shagged then? if so is it easy to time back up? ......eg where are the tdc marks on the pullys? cheers guys. Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted January 23, 2011 Admin Share Posted January 23, 2011 best to get the holy bible( haynes) gives you all the info in there is tight though m8 regards ollie Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted January 24, 2011 Share Posted January 24, 2011 best to get the holy bible( haynes) gives you all the info in there is tight though m8 regards ollie ebay it is then lol. cheers. Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted January 25, 2011 Share Posted January 25, 2011 Hi there take it's a CVH..... Bottom pulley(blue 1) got cut out and goes up to the big point on bottom cover, Cam pulley got a arrow and goes stright up and lines up with dot on the head... Hope this helps Quote Link to comment Share on other sites More sharing options...
