M4 Xr3I Cabbie 1.6Efi Starting Issues
Guest waynexr3i83
Guest waynexr3i83
HI im new too this group.....hope you guy can help me I HAVE A MK4 XR3I CABBIE WITH EFI ENGINE.....
A FW MONTHS BACK THE CAR WAS RUNNING THEN SUDDENLY JUST CONKED OUT AND GAVE UP.....
ON TURNING THE IGNITION WE FOUND THE CAR HAD NO SPARK......CHECKING EVERYTHING WE ESTABLISHED IT COULD BE THE COIL PACK............IT WASNT.........HAVE BEEN TOLD IT MAY BE THE CRANK SENSOR BUT CANT SEEM TO FIND ONE ON THE CAR..............
ANY HELP WILL BE MASSIVLEY APPRECIATED BEFORE I END UP LOSING MY RAG AND BEATING THE CAR WITH A BRANCH FAULTY TOWERS STYLE
CHEERS
WAYNE
i had the same problem the crank sensor is just above the starter motor as you look you'll see a 2 pin black connection that turns 90 degrees heading into where gearbox is attached hope this helps ps hope when replacing with new the old one doesnt crumble like mine did i had to split gearbox and engine to get it out !!!! let us know how you get on
Guest waynexr3i83
just found the sensor, the bastard plug had coe off lol...schoolboy error..need to recharge the battery and will let ya know if it starts tomorrow
Guest waynexr3i83
glad you found it lol took me a while.. yeh good luck mate hope it fires up as normal..
fired up a treat mate, even better just got me a classic insurance quote for 299 quid lol well chuffed
