Guest dave29 Posted November 16, 2010 Share Posted November 16, 2010 hi all. ive got a problem with the all blue that someone on here is bound to be able to solove lol. some times when i use it it is very juddery like its about to run out of juice but when i press the cut off switch in the boot it runs fine..........is this a common fault or have i got wiring issues? Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted November 16, 2010 Admin Share Posted November 16, 2010 sounds like its a dodgy cut of switch in the boot only way to find out is to bypass it and that will tell you if it is at fault pain in the butt them things untill you have a rear ender i suppose regards ollie Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted November 16, 2010 Share Posted November 16, 2010 sounds like its a dodgy cut of switch in the boot only way to find out is to bypass it and that will tell you if it is at fault pain in the butt them things untill you have a rear ender i suppose regards ollie how do you bypass them? Quote Link to comment Share on other sites More sharing options...
Guest varnie3i Posted November 17, 2010 Share Posted November 17, 2010 When I did it to mine I just disconnected the two wires going into the switch an connected them together. Simples Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted November 17, 2010 Share Posted November 17, 2010 Also check the wiring to the cut out switch as it tends to burn out and the connector plays up some times. Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted November 17, 2010 Admin Share Posted November 17, 2010 I agree the best is to disconnect the switch and join the 2 wires together. Remove the switch out of the wiring and see if this cures teh problem. Please let us know the results. Paul Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted November 17, 2010 Share Posted November 17, 2010 I agree the best is to disconnect the switch and join the 2 wires together. Remove the switch out of the wiring and see if this cures teh problem. Please let us know the results. Paul will do guys cheers. Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted November 19, 2010 Share Posted November 19, 2010 will do guys cheers. replaced the cut out switch from a scrapper n hey presto! sorted. cheers guys. Quote Link to comment Share on other sites More sharing options...
