Guest Rustler Posted September 5, 2010 Share Posted September 5, 2010 Hey guys... Trying to replace my W/Pump and of course both belts and tensioners etc etc .......Haveing trouble in removing or "Starting To Remove" the crankshaft pulley retaining bolt.....It's been in there over 19yrs....managed to remove all the other pullies etc but not "BIG BOY" SO..any help or suggestions would be welcome ,should i put back all the ancillary pulleys and belt? try to jam the flywheel or what, , Nother fine mess I've got in again...Dohhh ! ! ! Rustler ..The Oldest Cabbier... Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted September 6, 2010 Share Posted September 6, 2010 Do you have access to an air impact wrench ? I found this a great help when i needed to get mine off. Quote Link to comment Share on other sites More sharing options...
RScab Posted September 6, 2010 Share Posted September 6, 2010 I had the same problem a few weeks bac on a Fiesta My Air impact gun runnin @ 120PSI wouldn't even shift it. Ended up taken it 2 a local garage & asked them loosin it with their wagon impact gun That sorted it. Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted September 6, 2010 Share Posted September 6, 2010 Bloody NORA......answer 1......NO !! answer 2......Its now in bits, lots of bits....and my French aint too good !!! Question 2.....What Next ...????? .............HHHHHHHHHHHHHHHHHelp..!!!!! Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted September 8, 2010 Share Posted September 8, 2010 Hmmm another option is one of those extendable crack bars, like this one of the bay, i have 2 of these because i always manage to misplace one lol. http://cgi.ebay.co.uk/SEALEY-1-2-SQ-DRIVE-EXTENDABLE-BREAKER-BAR-450-600MM-/180547673085?pt=UK_Hand_Tools_Equipment&hash=item2a097adbfd Quote Link to comment Share on other sites More sharing options...
Paul Grainger Posted September 20, 2010 Share Posted September 20, 2010 Try putting it in 5th gear and and the hand brake on, then from the front of the car put your arm under with a long ring spanner, next pull for England, never failed me yet. Good luck Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted September 20, 2010 Share Posted September 20, 2010 Hey Guys....Yea..thanks for all your info'. Have ordered one of those 600mm extensions,from the UK,(If it comes) that will prob'ly be of use on that 32mm front hub nuts when I renew those C/V Gaiters. Also found that one of my ex-pat M8's has a imp'gun, but is waiting on new components from Uk for his air comp'.(just my !!!!ing luck) Meanwhile we'll give Pauls idea a go....trouble is at my age..77..I 'aint got much pull left now... come to think ,,,,can't recall pulling anything recently!!! Yea,, I "DO" mean "ANYTHING or ANYBODY"!!!!! Any road we'll get it sorted some-how,hopefully befor I kick that old bucket!!! Thanks again lads ......Rustler...The Oldest Cabbier.. Quote Link to comment Share on other sites More sharing options...
Guest Rustler Posted September 22, 2010 Share Posted September 22, 2010 Thanks, Thanks & More Thanks...... Well thanks to Cabbytech and Paul Granger, I've CRACKED that damned Crank Pulley NUT!!!!! Yea..Got me a 1/2" drive 15" ratchet power bar,a 3/8" socket,& a tie down ratchet strop (as used to tie down heavy loads on lorries) Tried pulling by hand ,"NO GO" ,Put strop round garage support pillar and other end round 15" bar handle,chocked all 4 wheels,h/brake on,& 5th gear. Got wife to ratchet up whilst I held bar and strop in place under car,(bar just back from vertical & just clear of floor) Full tension on strop ,still "NO GO"..but with a "gentle" pull on the bar from me....CRACK .."DONE IT". A bit dangerous,Yea,"Dont try this at home" as they say .........but it worked for us.."SO". on we go with W/Pump and belts renewal.... Once Again, Thanks Paul, Cabbytech & Cabby Club.. P/S found that the 3/8" socket was a better fit than an 18mm one. Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted September 22, 2010 Share Posted September 22, 2010 Well done m8, great news that you managed to sort it out, only happy that we could offer some type of help, but at the end of the day the credit goes to you for your persistance and winning Quote Link to comment Share on other sites More sharing options...
