MarineIguana Posted August 26, 2010 Share Posted August 26, 2010 Right seeing as it has been wet and making sure my battery doesn't go flat I started my cab up and it steams up, So go to switch on the rear screen heater and it trys to kill the engine so something is wrong with it but don't know where to start with it. Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted August 26, 2010 Share Posted August 26, 2010 When you put the rear heated screen on the revs should drop a little due to the ampere pull required for the heater, i would disconnect one of the wires from the screen first and try it again, if it still tries to kill the engine then there is a wiring fault of some description somewhere, and we will take it from there. Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted August 26, 2010 Author Share Posted August 26, 2010 Right so some sort of wiring fault then even with the screen disconnected as it acctually killed the engine had to turn it off didn't fancy a fire Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted August 26, 2010 Share Posted August 26, 2010 Your right, thats not good, it shouldnt kill the engine, it should just dip the revs for a few seconds and then recover, are you good with electrics ? the first thing is to check the feed wire is not broken between the car and the hatch and shorting to earth somewhere, find out what fuse feeds it, and the fuse size and then look at the heater switch and find out if there is anything else fed from it, Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted August 26, 2010 Author Share Posted August 26, 2010 I am OK with electrics  Cheers for the help will try it when it's not raining here lol. Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted August 26, 2010 Share Posted August 26, 2010 Nice one, good luck, let me know how you get on. Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted August 27, 2010 Author Share Posted August 27, 2010 found the problem some one has decide that the live feed for the fuel pump should come off the back off that switch idiots that's why it dies when you put it on now gotta see where the wire goes Quote Link to comment Share on other sites More sharing options...
gingergman Posted August 27, 2010 Share Posted August 27, 2010 thats proper cowboy! Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted August 27, 2010 Author Share Posted August 27, 2010 Think I should get another loom made for mine in the future don't trust this one much Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted August 27, 2010 Share Posted August 27, 2010 Well done, im pleased you found the problem, its amazing how many times you find bodge wiring on the back of switches that shouldnt be there. Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted August 27, 2010 Author Share Posted August 27, 2010 Yeah think it might have been a rush job whoever did the loom for it Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted August 30, 2010 Author Share Posted August 30, 2010 Right sorted it all out today moved the fuel pump wire to it proper location and the switch now works how it should just need a steamed up rear window to see if it's working fully but it should be  Cheers for all the help I appreciate it. Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted August 31, 2010 Author Share Posted August 31, 2010 So the screen isn't clearing but the switch is working so I need to see if the window is making a complete circuit, sod it Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted August 31, 2010 Share Posted August 31, 2010 O no, naughty heated rear window, did you check for power to the window and a good earth from it Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted August 31, 2010 Author Share Posted August 31, 2010 I have checked the window and it has a complete circuit no broken lines or stuff just need to see if any power is coming up to the connections to it. Quote Link to comment Share on other sites More sharing options...
