Guest burnhamshaun Posted August 23, 2010 Share Posted August 23, 2010 hey guys ive just joined and am in need of some help ive just brought a mk4 st frozen white escort cabriolet and cant sus out why the roof isnt working when the switch is pressed there is a click from the boot but nothing happens and the oil level is below minimum on the resivoir in the boot advice please on what to check and how ive also noticed that if i can get it working then will need new seals on the lifters/rams as there is oil residue around the seals Quote Link to comment Share on other sites More sharing options...
badger Posted August 23, 2010 Share Posted August 23, 2010 (edited) hey guys ive just joined and am in need of some help ive just brought a mk4 st frozen white escort cabriolet and cant sus out why the roof isnt working when the switch is pressed there is a click from the boot but nothing happens and the oil level is below minimum on the resivoir in the boot advice please on what to check and how ive also noticed that if i can get it working then will need new seals on the lifters/rams as there is oil residue around the seals hi and welcome to the club. so to start open the tap on the side of the pump and make sure the roof will open and shut ok manually. then shut the tap and see if it works there could be an electrical problem or the pump could be damaged and in need of repair if it still dosn't work. Edited August 23, 2010 by badger Quote Link to comment Share on other sites More sharing options...
Guest burnhamshaun Posted August 23, 2010 Share Posted August 23, 2010 It works fine manually but not on the button is there any way I can try the pump by bridging wires etc Quote Link to comment Share on other sites More sharing options...
gingergman Posted August 23, 2010 Share Posted August 23, 2010 sounds like you need some new rams if there leaking lol, ive got a good pair for a tenner! Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted August 23, 2010 Share Posted August 23, 2010 hi and welcome to the club. so to start open the tap on the side of the pump and make sure the roof will open and shut ok manually. then shut the tap and see if it works there could be an electrical problem or the pump could be damaged and in need of repair if it still dosn't work. Hi mate Just want to make sure but is it a factory fitted roof or has someone fitted it after? Don't take this the wrong way but are you doing it properley, key the key once! If you are check the thermal cut out, it's the metal looking fuse by the motor. Swap it for a 20 amp fuse to see if that works. If not check the relays, there are 2 in the boot by the pump just under the rear light. If it is a factory fitted motor then there are 2 more relays under the dash drivers side. If they are ok and it is a factory fitted motor there are safety earths on the inside of the rear speaker pods which earth out when you put a cover so stops you being to put the roof up with it on, check they haven't come away and earthing out anywhere. While checking that like stu said check the rams are not leaking. You will need to top the level back up but as it is on the min means there should be enough fluid to make the roof work Quote Link to comment Share on other sites More sharing options...
Guest burnhamshaun Posted August 24, 2010 Share Posted August 24, 2010 You sure know your stuff lol where abouts are you based fancy having a look with me :-) lol how would I know if it's factory fitted it has relays behind the back passenger light if this helps and the switch by the gear stick Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted August 24, 2010 Share Posted August 24, 2010 I have just worked on a few mate thats all lol. Does the wiring look old and original? I am in Hampton, Surrey but would be more than glad to give you a hand though if your close enough. Quote Link to comment Share on other sites More sharing options...
Guest burnhamshaun Posted August 25, 2010 Share Posted August 25, 2010 You may even know the car it's a White cabriolet with a grey mohair roof I'd be more then willing to come to you if you think we could source the problem between us ;-)) Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted August 25, 2010 Share Posted August 25, 2010 Yeah we should be able to sort it Quote Link to comment Share on other sites More sharing options...
