Guest suffolk04 Posted August 6, 2010 Share Posted August 6, 2010 any common faults to look at on these? not too sure if its the uj knocking or maybe a worn bush somewhere? Quote Link to comment Share on other sites More sharing options...
Guest richie29gt Posted August 6, 2010 Share Posted August 6, 2010 u sure its not the cv joint when does it knock straght line or when u are turning Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted August 6, 2010 Admin Share Posted August 6, 2010 have you got play in the steering colum when standing still is there play up and down if so you can get a bush kit and is easy to do regards ollie Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted August 6, 2010 Share Posted August 6, 2010 if i rock the steering when stationary, i can hear it and feel it before and after the uj. Is it just one bush or two ollie? i know thers one just behind the steering wheel, are there more further down the column Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted August 6, 2010 Admin Share Posted August 6, 2010 if i rock the steering when stationary, i can hear it and feel it before and after the uj. Is it just one bush or two ollie? i know thers one just behind the steering wheel, are there more further down the column thats the ones m8 you can get the full kit Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted August 7, 2010 Share Posted August 7, 2010 where does the other bush fit? thought there was only one behind the steering wheel Quote Link to comment Share on other sites More sharing options...
Guest Mark Freshrides George Posted February 21, 2014 Share Posted February 21, 2014 Just for future reference. This is what happens if you don't get the notch lined up when re-fitting the steering wheel. This will cause you massive problems if the bush doesn't sit straight and the steering will bind and not self-centre. Quote Link to comment Share on other sites More sharing options...
