Guest peter1 Posted July 29, 2010 Share Posted July 29, 2010 hi all, I'm having a couple of problems with smooth running and am told that I need a new idle air control valve sensor and a throttle body sensor for my R reg cabby. I hanen't got a clue except that the cost seems to be about £500 for the pair. does anyone know where to get them at a more reasonable price cheers, peter s-b. Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted July 29, 2010 Share Posted July 29, 2010 Try ebay for second had stuff which will be cheap or a place like euro car parts for new patern parts which are cheaper than ford parts Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 29, 2010 Share Posted July 29, 2010 try your local scrappy, will only cost a few quid Quote Link to comment Share on other sites More sharing options...
allblue Posted July 29, 2010 Share Posted July 29, 2010 Before you write off the sensors, try cleaning the Idle valve with carb cleaner. Over time excess carbon builds up inside these, affecting piston movement. Simply open up the idle valve and spray carb cleaner to remove carbon deposits. Leave to dry. Ensure the piston moves freely. Refit after all carb cleaner has evaporated. Quote Link to comment Share on other sites More sharing options...
