MarineIguana Posted June 22, 2010 Share Posted June 22, 2010 Right I have a problem, I have always been able to hear my fuel pump working continuously (dunno if this is normal) but now it seems to prime and then never carry on pumping unless I switch off the ignition and start again then the same problem and this is what is causing my cab to not run I think as there is no fuel getting to the engine after it has turned over for the first time. It will start every time and go to run but just cuts out due to lack of fuel I think. I have new fuel pump so doubt it is that getting bummed out cos of it Quote Link to comment Share on other sites More sharing options...
Guest r1cky Posted June 22, 2010 Share Posted June 22, 2010 arent these prone for the fuel pump relay big purple relay under the drivers foot well Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted June 22, 2010 Share Posted June 22, 2010 sounds like either relay(purple 1 under dash) or mine had simalar fault and dizzy was knackered well the power pack only found this when i banged the dizzy and it started.....try un-plugging the relay when it cuts out and plugging back in and see if pump kick's back in.... if not see if plugs got a spark. mine use to cut out then start after 2-3 mins or after unpulgging relay for fuel pump then be fine until you turned it off.... Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 22, 2010 Author Share Posted June 22, 2010 I'll try when daylight gets here again My dizzy is new and has got a good spark just fuel pump isn't doing what it used to so I am assuming this is the problem I hope Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted June 22, 2010 Share Posted June 22, 2010 penny to a pound its the relay most comon fault on mk3 xr3i,rs ts and well just about anything they fitted the mfi engine to Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 23, 2010 Author Share Posted June 23, 2010 Great one more thing to replace will be like new when I bloody get on the road :( Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 23, 2010 Share Posted June 23, 2010 at least there easy to change lol you wont get ya hands to dirty! Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 23, 2010 Author Share Posted June 23, 2010 Yeah I'll test it when I get up with a meter see if it is knackered if it is new one Got both side lights working now too lol Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 23, 2010 Author Share Posted June 23, 2010 Well I would test it if I had one My pump is on a switch forgot to mention that bit so the relay may have been by passed Quote Link to comment Share on other sites More sharing options...
Guest r1cky Posted June 23, 2010 Share Posted June 23, 2010 should be up under the dash on the drivers side should look like this Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 23, 2010 Author Share Posted June 23, 2010 Nope cant see that its not easy to miss now is it so no relay, I'm lost as what the problem is now apart from no relay of course Quote Link to comment Share on other sites More sharing options...
Guest r1cky Posted June 23, 2010 Share Posted June 23, 2010 is there a relay on the switch wire you've got for the pump there should be some sort of relay as its switching off Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 23, 2010 Author Share Posted June 23, 2010 Well my car is running now so I need to get a relay fitted but that can wait till its on the road cheers for da help Quote Link to comment Share on other sites More sharing options...
Guest bigjon Posted June 23, 2010 Share Posted June 23, 2010 hi glad u got your cab running ifm a have a s1 loom and engine u will need the big silver feul pump relay no the purple one as they r for the s2. Quote Link to comment Share on other sites More sharing options...
MarineIguana Posted June 23, 2010 Author Share Posted June 23, 2010 I'll keep my eye out for it cheers Quote Link to comment Share on other sites More sharing options...
Guest rodge Posted June 24, 2010 Share Posted June 24, 2010 I have an intermittent problem with mine. Sometimes when I turn the ignition on the fuel pump doesn't pump. I simply turn it off and start again until I hear the fuel pump kick in. How do you know if the relay is working or not? Dave, Quote Link to comment Share on other sites More sharing options...
