Guest georgeking Posted May 23, 2010 Share Posted May 23, 2010 will a mk6 si escort fuse box fit a mk5b si escort as looks the same but relays are in diff place any ideas?????????????? Quote Link to comment Share on other sites More sharing options...
Guest Justin Posted June 2, 2010 Share Posted June 2, 2010 Fairly sure it won't fit. Look on the bottom. the Mk5b fusebox has three feeds from the battery. I believe the mk6 fusebox has just 1.. I had to get a new fusebox for my mk5b from Ford a while ago and was supplied with a mk6 one first. No way it would ever have fitted, as some of the wiring loom plugs are different too i believe.. Quote Link to comment Share on other sites More sharing options...
Guest georgeking Posted June 3, 2010 Share Posted June 3, 2010 mines only has one live with nut on it is there more and all the plugs are the same but when i plug a mk6 box in it smokes anymore help on this have you got a pick of bottem by any chance thanks Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted June 8, 2010 Share Posted June 8, 2010 The best thing is to swap like for like, there are quite a few variations of the fuseboxes so to be safe use a fusebox with the same reference/part numbers. Quote Link to comment Share on other sites More sharing options...
Guest vinnyvangough Posted June 9, 2010 Share Posted June 9, 2010 You need a fusebox with the SAME part number else you will end up with untold problems Quote Link to comment Share on other sites More sharing options...
Guest barclayrob Posted February 16, 2014 Share Posted February 16, 2014 Hi guys - may I please ask where you can find the part number on the fuse box ? I have a 1996 N Reg 1.8 Si 130bhp. Many thanks, Rob Quote Link to comment Share on other sites More sharing options...
Vincygav Posted February 16, 2014 Share Posted February 16, 2014 They do fit, only thing you need though is for the last 3 letters to match up. At the moment I am running a mk5 fusebox in my mk5b. Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 16, 2014 Share Posted February 16, 2014 Hi guys - may I please ask where you can find the part number on the fuse box ? I have a 1996 N Reg 1.8 Si 130bhp. Many thanks, Rob Your best off starting a new topic mate, this one is near 4 years old and is for a different problem! Quote Link to comment Share on other sites More sharing options...
