Guest cossiemark Posted April 13, 2010 Share Posted April 13, 2010 (edited) what modifications will i need to do?? the wheels i will be fitting are 17" rs 7 soft spokes 7 1/2 x 17 with 205/40/17 tyres?? cheers Edited April 13, 2010 by cossiemark Quote Link to comment Share on other sites More sharing options...
Guest kevindent Posted April 13, 2010 Share Posted April 13, 2010 YOU WILL NEED TO ROLL ARCHES MATE OR THEY WILL RUB LIKE A B**CH Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted April 13, 2010 Share Posted April 13, 2010 i have 17" alloys on mine and did not need to adapt anything. my wheels are a multifit so they went straight on but would advise against lowering the car with these on Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted April 13, 2010 Share Posted April 13, 2010 If depends what cab you have. MK3/4 on standard suspension not much though you will get arch rubbing if car is loaded up. If its lowered you will need to roll the archs. Would be better if you had a narrower tyre on the rim eg. 195/40/17. The MK5/6 should be problem free unless the car is lowered alot Quote Link to comment Share on other sites More sharing options...
Guest vinnyvangough Posted April 13, 2010 Share Posted April 13, 2010 My mk3 has 205/40/17 on standard suspension and is fine loaded Quote Link to comment Share on other sites More sharing options...
Guest steelcabby Posted April 14, 2010 Share Posted April 14, 2010 (edited) seems to be alot of mixed anwsers here...lol. if your using the right wheels for the car with the right offset you will get 17"'s on the car with a 35mm drop on either a full G-MAX suspension kit or coilovers. mine was riding on 17" 205-40-17 tyres and a full G-MAX 35mm kit with no rubbing even when it was fully loaded oh and the arches where mint and never rolled as i hate rolling arches. bodges the car IMO Edited April 14, 2010 by steelcabby Quote Link to comment Share on other sites More sharing options...
Guest wodge Posted April 15, 2010 Share Posted April 15, 2010 mine is lowered on 17's and sed to rub with just me in.....arches rolled = no more rubbing Quote Link to comment Share on other sites More sharing options...
Guest steelcabby Posted April 17, 2010 Share Posted April 17, 2010 mine is lowered on 17's and sed to rub with just me in.....arches rolled = no more rubbing looks like you have a 60mm drop on that tho?? thats loads lower than mine was Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted April 17, 2010 Share Posted April 17, 2010 Am I just being thick but what does rolling the archs consist of? Quote Link to comment Share on other sites More sharing options...
Guest vinnyvangough Posted April 18, 2010 Share Posted April 18, 2010 Well my MK3 is standard ride height and i have just tried 215/45/17 on the front and they are no good. They rub. Whereas the previous 205/40/17 were fine Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted April 18, 2010 Share Posted April 18, 2010 i have 17" with 205/40/17 tyres on with a standard ride height standard shock and spring set up and have not had any problems Quote Link to comment Share on other sites More sharing options...
Guest vinnyvangough Posted April 18, 2010 Share Posted April 18, 2010 Right, well put the 215/45/17 on the rear and they rub too. So 205/40/17 are the biggest you can go Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 18, 2010 Share Posted April 18, 2010 205/40/17 is the biggest you can go with lowering 30-40mm, any bigger or any lower it will cause problems Quote Link to comment Share on other sites More sharing options...
Guest vinnyvangough Posted April 18, 2010 Share Posted April 18, 2010 Well just ordered up a set of 4 Toyo Proxes T1R's for my Compomotive MO's in 15". Wont have to worry about rubbing now Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 18, 2010 Share Posted April 18, 2010 15s give a much better ride, just dont look as good imo, still, im rolling on 15s Quote Link to comment Share on other sites More sharing options...
Guest wodge Posted April 20, 2010 Share Posted April 20, 2010 Am I just being thick but what does rolling the archs consist of? basically the metal lip of the arch gets bent upwards into the arch to create more space for the wheel. Quote Link to comment Share on other sites More sharing options...
Guest vinnyvangough Posted April 20, 2010 Share Posted April 20, 2010 15s give a much better ride, just dont look as good imo, still, im rolling on 15s True, but when the 15's are Compomotive MO 1561's, they will look better than good Quote Link to comment Share on other sites More sharing options...
Guest steelcabby Posted April 20, 2010 Share Posted April 20, 2010 (edited) you can't go any wider than 205 as iirc they catch the shock. but it depends on the offset you have. but then if you have the right offset and you were rolling with 215's then you'd need wider arches to cover the wheels sticking out the arches. you can get 17's on with the escort offset. on standard shocks too. but when fully loaded or cornering hard they will roll and rub somewhere garanteed. so uprated shocks and springs like G-MAX 35mm sports suspension... or coilovers and you will get a firm ride with 17's that don't rub. and don't need the arches rolling for.. hope that helps peeps Edited April 20, 2010 by steelcabby Quote Link to comment Share on other sites More sharing options...
