Guest Soggyllama Posted April 1, 2010 Share Posted April 1, 2010 Ok when my engine gets hot, my oil light comes on and stays on I've checked the oil level this morning and the levels are fine, in fact its just a smidge above the max marker on the dipstick. There is no oil in my engine bay anywhere where it shouldn't be (I.e its all IN the engine) the cap is a bit loose but secure, as in you really need the effort to pull it off, but it spins freely while sat. The various pipes seem clear . does anyone have any ideas why this is happening? I'm planning on a service soon, but would like to know why the light is on before servicing in case its a major problem. What other checks can I do to make sure its not going to a serious problem? Thanks Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted April 1, 2010 Share Posted April 1, 2010 Hi, does the oil light go out straight away when you rev the engine ? if so it sounds like the oil sensor needs replacing as its gone faulty. Quote Link to comment Share on other sites More sharing options...
chaz Posted April 1, 2010 Share Posted April 1, 2010 when it happened to mine it was the oil switch / sensor. Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 2, 2010 Share Posted April 2, 2010 bonus if it is just that as they are only a few quid to buy! Quote Link to comment Share on other sites More sharing options...
Guest KarlosG Posted April 6, 2010 Share Posted April 6, 2010 If it goes out when you rev it then that points to low oil pressure, if a new switch doesnt sort it out then the engine needs a rebuild.... big ends/mains will be worn Quote Link to comment Share on other sites More sharing options...
