Guest trueiron Posted March 8, 2010 Share Posted March 8, 2010 Hi All Couple of problems I could do with some help on 1. Temp. Car runs fine and when one the move the temp guage stays in the middle. As soon as I hit traffic it starts going up to the red, but the fan cuts in just as it is about to hit the red. Have changed the temp sensor checked for gasket problems, checked the radiator and cooling system are all good. Any ideas 2. Fan Belt - just replaced the fan belt with a new one, but when we put it on - the adjustment is on its max. The fan belt is still amking a noise at times, other times is fine Any advice on the little problems would be great as we have just spent a fortune rebuilding the top end of the engine, replacing valves etc Shane Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 8, 2010 Share Posted March 8, 2010 are you sure its the correct fan belt fitted? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted March 8, 2010 Share Posted March 8, 2010 Hi shane the temp is about right but you can get different thermostate temp check what temp is stamped on your's or just get lowest.think it is 82 degrees or lower fan will come on sooner.......the fan belt you have wrong sixe by the sounds of it.the 1 you got take with you and ask for smaller 1 you may have to wind it on but should be ok...had prob like this before and done it was fine with little of adjustment needed.. hope this helps Quote Link to comment Share on other sites More sharing options...
Guest trueiron Posted March 9, 2010 Share Posted March 9, 2010 Cheers Guys We changed the temp sender to an 82 before but still does the same - as long as there are no problems though I guess I will have to live with it Will try the fanbelt again and see what happens - According to the computer it is the correct one though Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 9, 2010 Share Posted March 9, 2010 my old cab done that with the temp aswell, never sorted it, it was just the way it was, never caused me no issues with overheating etc Quote Link to comment Share on other sites More sharing options...
Guest trueiron Posted March 10, 2010 Share Posted March 10, 2010 Just had the belt off again and looks like the tensioner is worn. It has 2 lugs showing so thats the next stop Quote Link to comment Share on other sites More sharing options...
chaz Posted March 10, 2010 Share Posted March 10, 2010 Let us know how you get on mate. Quote Link to comment Share on other sites More sharing options...
Guest Clive Posted April 3, 2010 Share Posted April 3, 2010 Hi, Don`t get your fan switch mixed up with your temp sender. Fan switch on top of thermostat housing, temp sender Below. Quote Link to comment Share on other sites More sharing options...
