Guest Pierce Posted February 23, 2010 Share Posted February 23, 2010 can someone give me a list of what I need to put a 2ltr zetec into my 1988 MK4 MFI cab and run the turbo box already fitted Quote Link to comment Share on other sites More sharing options...
badger Posted February 24, 2010 Share Posted February 24, 2010 (edited) a basic list would be zetec engine loom 2ltr mondeo engine escort zetec sump and pickup pipe escort zetec flywheel ofab/ofac ecu as above plus you can use mk4 efi loom and ecu zetec escort water pump zetec alternator you can use gearbox,starter moter from cvh i'd uprate clutch i'm on my second rs turbo clutch and will uprate to racing clutch next. i needed to uprate gearbox mounts as well. you need exhaust manifold and down pipe to mate the exhausts up. you need to modify engine mount. and make some mix and match water pipes. a lot of people go straight for the 1.8 130bhp escort lump as there's a lot less work. if your intrested in doing this i can guide you through it as i am currently running this system in my mk4 at the moment. and as they say i have been there and done it. Edited February 24, 2010 by badger Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted February 24, 2010 Share Posted February 24, 2010 ofab/ofac is that the ecu code Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted February 24, 2010 Share Posted February 24, 2010 see tacha she is breaking one at the moment Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted February 25, 2010 Share Posted February 25, 2010 i have a 1.8 mondeo on an R coming sat so I'm gonna fit the engine out of that. can you tell me what i need an how to fit it Quote Link to comment Share on other sites More sharing options...
badger Posted February 26, 2010 Share Posted February 26, 2010 i have a 1.8 mondeo on an R coming sat so I'm gonna fit the engine out of that. can you tell me what i need an how to fit it same as above mondeo and escort zetec's are not the same so still need all that was mentioned in above posts Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted April 22, 2010 Share Posted April 22, 2010 the mondeo has the plastic inlet do I need to change this also need help with the wiring on the square plug on the right hand side of the bay by the battery Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted July 18, 2010 Share Posted July 18, 2010 got the engine in going to get inlet and wiring from a early efi zetec in an escort what wiring do I need from the car its going in a mk4 mfi Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted July 18, 2010 Share Posted July 18, 2010 i've been and got the inlet ECU and some of the loom from a M reg escort xr3i I need to know what wiring I need to do Quote Link to comment Share on other sites More sharing options...
