Guest xr2madman Posted February 6, 2010 Share Posted February 6, 2010 hi all ive just spent the last two days in the cold and wet changeing my clutch and gear box no put back together the whole car vibrates so bad i did though have problems undoing the engine mount on drivers wing as it was spining do you think ive broke the mount any help would be great many thanks damian Quote Link to comment Share on other sites More sharing options...
Guest traceyswifti Posted February 6, 2010 Share Posted February 6, 2010 hi damian its possible. try changin them Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 6, 2010 Share Posted February 6, 2010 is the clutch alined properly? did u replace the thrust bearing, as that can cause serious judder if broke. Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted February 6, 2010 Share Posted February 6, 2010 is it a mk4 escort and if it is dose it feel like it all the time even at tick over if so would go for engine mounts touching on the beam under the gearbox as ive seen em put back together wrong. Quote Link to comment Share on other sites More sharing options...
Guest xr2madman Posted February 6, 2010 Share Posted February 6, 2010 thanks all the gear box fitted to the clutch ok gingerman and replaced bearing many thanks all damian Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted February 6, 2010 Share Posted February 6, 2010 is it sorted or and if so what was it? Quote Link to comment Share on other sites More sharing options...
Guest xr2madman Posted February 8, 2010 Share Posted February 8, 2010 no car not sorted yet mossop wish it was its getting me down as realy like to drive it Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted February 8, 2010 Share Posted February 8, 2010 It could be the engine mount on the drivers side that has passed its sell by date, try this, put car in 2nd gear, and try to set off and then stop again, see how much the gearstick moves, if it looks like it wants to jump out of the car then a mount is broken, if there is little movement then something else is amiss. Did you remove the ball joint to gain more room to remove the gearbox ? double check tightness of all nuts and bolts, plus did you put the clutch plate on the right way round ? Quote Link to comment Share on other sites More sharing options...
Guest xr2madman Posted February 8, 2010 Share Posted February 8, 2010 hi cabbie tech think it could be mount as the top bolt was spinning and has pulled out of the rubber im watching one on ebay at min hope it sorts it out when done its horrid to drive sure i put clutch right way round as it says clutch side on new clutch well hope i did any way lol i vibrates when car in or out of gear many thanks for help will let you know when done mount when get one thanks damian Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted February 8, 2010 Share Posted February 8, 2010 fingers crossed mate Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted February 9, 2010 Share Posted February 9, 2010 From what you said about the vibrating in or out of gear, i agree with you and think its down to that engine mount, good luck with it m8. It prob said flywheel side on the clutch plate lol. Quote Link to comment Share on other sites More sharing options...
Guest xr2madman Posted February 9, 2010 Share Posted February 9, 2010 thats what the clutch said but because we was rushing and it was peeing it down we might have put it the wrong way round if it aint the mount gonna try clutch engine out for the 3rd time lol dont you just love working on cars in the rain lol thanks all for all your advice and help damian Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted February 9, 2010 Share Posted February 9, 2010 are you sure you tightened up the clutch cover? as cabby said double check the mounts and bolts you took out....you said you took engine out why? Quote Link to comment Share on other sites More sharing options...
Guest xr2madman Posted February 9, 2010 Share Posted February 9, 2010 took engine out to change clutch and gear box and to have a clean round the bay hopefully gonna try a mount off my mates car if the same this thursday thanks again guys will let you know how it goes Quote Link to comment Share on other sites More sharing options...
Guest xr2madman Posted February 16, 2010 Share Posted February 16, 2010 hi all ive sorted it car now realy nice to drive love it again just got to sort damage out now on wing then gonna spend ages cleaning the old girl up many thanks all damian Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 16, 2010 Share Posted February 16, 2010 i take it it was the mount then mate? get that front wing done and show her even more love Quote Link to comment Share on other sites More sharing options...
