Guest Eastw77 Posted January 31, 2010 Share Posted January 31, 2010 Hi, I have a 1984 cab, it is an XR3i with Bosch K-Jetronic MFi. The problem I am having is when the engine is left to idle it is hunting between about 500rpm and 1500rpm. It also often cuts out when dropping on the low side. Any ideas as to what the problem could be would be greatly appreciated. many Thanks from New Zealand, Ian Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 31, 2010 Share Posted January 31, 2010 have you tried the idle control valve mate? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted January 31, 2010 Share Posted January 31, 2010 have you tried cleaning out injection with carb cleaner this might help and as gingergman said the idle control valve might need cleaning remove and spray with carb cleaner..... Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted January 31, 2010 Share Posted January 31, 2010 Yeah same as above mate, has it just started to happen Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted January 31, 2010 Share Posted January 31, 2010 dont think that injection had an icv as to early i would be thinking air leak or maybe mixture. Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted January 31, 2010 Share Posted January 31, 2010 as mossop said check for air leak and mixture.....you can also adjust thottle stop...it should have a wire going to it with elbow connector turn the screw a little bit should help. Quote Link to comment Share on other sites More sharing options...
Guest Eastw77 Posted January 31, 2010 Share Posted January 31, 2010 Thanks guys, I havn't looked at it yet. I just thought I would get some pointers to start me in the right direction. It has just started happening, it was fine a couple of weeks ago. A bit of a stupid question but how do you go about locating air leaks? cheers, Ian Quote Link to comment Share on other sites More sharing options...
Guest DEG Posted February 1, 2010 Share Posted February 1, 2010 hi pal. at college we test air leaks with carb cleaner spraying it on pipes and pipe joints if it changes the idle then thats where your leak is. Quote Link to comment Share on other sites More sharing options...
