Guest Dojomaster1984 Posted January 30, 2010 Share Posted January 30, 2010 Here is a question that no one else seems to have asked before. I have a non LSD MK3 XR3i and i now have a spare non LSD MK4 rs gearbox. I cannot use the gearbox due to the mount differences, so can i just open my MK3 gearbox up and swap everything over from the Mk4 box. They both came off of 1.6 cars. HA HA try and figure that one out ladies and gentlemen. Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted January 30, 2010 Share Posted January 30, 2010 (edited) i do beleave you can swap the bits from case to case but why i would have to ask? Edited January 31, 2010 by mossop1 Quote Link to comment Share on other sites More sharing options...
Guest Dojomaster1984 Posted January 31, 2010 Share Posted January 31, 2010 I have a problem with engaging the gears, so its probably a synco issue. So a swap out of a box i has seems the best way rather then buying a new box. Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted January 31, 2010 Share Posted January 31, 2010 Hi have you tried swapping the mounting bolt's from mk4 box to mk3?if not try that i'm sure i've done this in the past.......worth a try and could save you ££££££££ Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 31, 2010 Share Posted January 31, 2010 Hi have you tried swapping the mounting bolt's from mk4 box to mk3?if not try that i'm sure i've done this in the past.......worth a try and could save you ££££££££ i believe the bell-housing is diffrent on the mk3 box to mk4?? Quote Link to comment Share on other sites More sharing options...
Guest Dojomaster1984 Posted January 31, 2010 Share Posted January 31, 2010 yeah the gearbox mounts differently on the mk4. So a gearbox from a MK3 can be put onto a MK4 but not the other way. Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted January 31, 2010 Share Posted January 31, 2010 Good luck with it mate Quote Link to comment Share on other sites More sharing options...
Guest Dojomaster1984 Posted February 1, 2010 Share Posted February 1, 2010 i will post what happend win or loss Quote Link to comment Share on other sites More sharing options...
Guest Dojomaster1984 Posted February 20, 2010 Share Posted February 20, 2010 Ok i have been trying to figure this out. But i cannot. The gearbox is in place. I can use a screwdriver to get the gearbox into every gear, But when i try to attach the gear rod i cannot get it out of that gear. It would seem that the gearbox needs less travel in order to change gear. So do I need the gear lever set from a MK4 rather then a MK3? Thanks for reading Quote Link to comment Share on other sites More sharing options...
Guest Dojomaster1984 Posted February 20, 2010 Share Posted February 20, 2010 the only difference between this gearbox and the old one, is that this one has a selector plate inside the box as where the old gearbox did not have one. Quote Link to comment Share on other sites More sharing options...
