Guest 73836 Posted January 27, 2010 Share Posted January 27, 2010 My electric aerial has stopped going up and my heated from windscreen is not working. Any ideas? Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted January 27, 2010 Share Posted January 27, 2010 I would presume they are fused so check them after that check the earths then poss relay sorry im not much help on theese things but tend to just scratch me head till i find fault lol hope that helps. Quote Link to comment Share on other sites More sharing options...
chaz Posted January 28, 2010 Share Posted January 28, 2010 My electric aerial has stopped going up and my heated from windscreen is not working. Any ideas? Reading the title I thought you need an agony Aunt, Im pleased to read it's only a simple thing like the aerial. Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted January 28, 2010 Share Posted January 28, 2010 Reading the title I thought you need an agony Aunt, Im pleased to read it's only a simple thing like the aerial. Or is the aerial a cover up lol Quote Link to comment Share on other sites More sharing options...
Guest 73836 Posted March 21, 2010 Share Posted March 21, 2010 Can someone point me to a place on the forum that details the different relays and their locations? I have a Mk6 cab in Imperial Blue (I hope - colour code HX4). Thanks Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted March 31, 2010 Share Posted March 31, 2010 If your heated windscreen has stopped working, check the power relay and the 50A fuse located on the front of your battery, the screen only works with the engine running. Does the lamp in the switch come on ? The screen is operated as 2 seperate sections, so i would suspect an electrical problem rather than a complete screen failure. The ariel operates via a signal from the radio, does the radio switch on ok ? it might just be that the mast is stuck in the bottom of the ariel housing. Quote Link to comment Share on other sites More sharing options...
Guest dinky Posted April 1, 2010 Share Posted April 1, 2010 my electric ariel is not working any ideas would this be fused ?can find anythink on the diagram Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted April 4, 2010 Share Posted April 4, 2010 is it old mate maybe be siezed was it working ok before? Quote Link to comment Share on other sites More sharing options...
Guest dinky Posted April 5, 2010 Share Posted April 5, 2010 the last one didnt work and was bent so i got another fitted it but this does'nt work i was told it worked when i got it could this be a wiring problem or fuse please can someone help thanks peter Quote Link to comment Share on other sites More sharing options...
