No Heat In Cold Cabby
Guest wildsquaddie
Guest wildsquaddie
Hi, can anyone help warm my cabby up. On tick over the heaters work slightly, when im on the road driving, the warm air comming through the blowers turns really cold, as it is really cold outside. I have not got a clue what it could be, please help
Check all hoses for signs of blockage.. if the heater starts warm and then goes cold when engine is under load then the water isnt doing a full circui
Hi mate i would prob say your heater matrix is blocked and water is not going all round matrix...you can take both hoses off and try puttig pressure washer through it to clean it.....done this to my mk4 cabbie matrix(was out of car tho) had simalar problem no heat when driving and it was blocked with brown gunk..good luck
As sum of the lads hav said
check
coolant level
are both pipes goin 2 the matrix gettin warm (if one is cold then matrix blocked)
is the thermostat workin correctly
water pump may be faulty (not circulating correctly)
is the radiator fan comin on to early
