Guest mickiemackiemoo Posted November 24, 2009 Share Posted November 24, 2009 Ive allways looked on here but never joined and posted so here goes got it back in 2007 with 80k on the clock standard at 87k the bottom end went, plus the gearbox wasent to heathly. due to fact i had a company van + couldnt be bothered, i let it sit for about a year + half! so this autumn i finally pulled my finger out and started work on it!! picture dairy engine + box out!!! brand new bottom end + gearbox cylinder head reworked + cleaned up Head back on Got some 5 spoke from Ford Racing Usa Taking shape slowly As it sits at the minute Done so far.. New engine New Gearbox New standard brakes allround New wishbones,antiroll bar links, tie rod + ends Reworked cylinder head Lowered on FK coilovers Mongoose full stainless system Colour coded side indicators Ford racing 17" alloys To do Fit the cambelt add fluids, gearbox/engine + coolant rework the induction pipe to use the standard airbox with a decent aftermarket air filter footwell lights laguna front splitter Then once its runing ok + run in fit mondeo 278 front brake setup using mondeo calipers and cosworth discs convert rear drums to disc's there's proberly more todo i've forgotten . cheers Mickie Quote Link to comment Share on other sites More sharing options...
chaz Posted November 24, 2009 Share Posted November 24, 2009 Welcome to cabbyland mate, Cab looks really good so is the list of things you doing to it. Keep updating mate. Quote Link to comment Share on other sites More sharing options...
