Guest rsturbz Posted September 30, 2009 Share Posted September 30, 2009 Hi 2 all I have a mk4 xr3i cabi the roof is electric but it does not close about 3 to 4 inches and if i pull it hard it does not sit inline with the seals on top of the wind screen i have looked at the electric motor and the fluid is below min i think it could be the problem. But does anyone know how to top the fluid up as i downt have a clu and its my 1st mk4 cabi on a electric roof please could some one help me out thank you Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted October 11, 2009 Share Posted October 11, 2009 (edited) Hi 2 all I have a mk4 xr3i cabi the roof is electric but it does not close about 3 to 4 inches and if i pull it hard it does not sit inline with the seals on top of the wind screen i have looked at the electric motor and the fluid is below min i think it could be the problem. But does anyone know how to top the fluid up as i downt have a clu and its my 1st mk4 cabi on a electric roof please could some one help me out thank you there is a allen key type bolt in the top of the motor.the motor is located in the boot behind the left hand side boot interior panel.simply remove the pannel and take the bolt out of the pump then top up the fluid till it reaches the max mark on the reserviour. jobs a guddun. Edited October 11, 2009 by dave29 Quote Link to comment Share on other sites More sharing options...
Guest technoferret Posted October 17, 2009 Share Posted October 17, 2009 I also want to top mine up but I dont have a manual so could someone tell me what kind of fluid I use (Transmission/power steering fluid ? Brake fluid? LHM? or some ridiculously expensive special stuff? etc) Thanks Quote Link to comment Share on other sites More sharing options...
Guest pauls0701 Posted October 17, 2009 Share Posted October 17, 2009 dont know what the proper stuff you are ment to use but used jack oil in mine as that was all i had laying about at the time lol works fine though Quote Link to comment Share on other sites More sharing options...
Guest cooldad175 Posted October 25, 2009 Share Posted October 25, 2009 Hi everyone I bought the gizmo for fitting a new cog to the motor but I lost the instruction leaflet and in it it tells you the correct type of fluid to use when topping up and the best place to buy the fluid. Perhaps the moderator of this site could help us out and also I wonder if he could let me have the instruction leaflet as well. Regards Quote Link to comment Share on other sites More sharing options...
Guest taz1787 Posted October 25, 2009 Share Posted October 25, 2009 any brake and clutch fluid any hydrolic fliud but not lhm as can rot rubbers and as stated undo allen key bolt fill up then bleed system Quote Link to comment Share on other sites More sharing options...
Chris Posted October 26, 2009 Share Posted October 26, 2009 I do have for sale a bottle of genuine ford power roof fluid..500ml..still sealed..the correct weight for the pump Quote Link to comment Share on other sites More sharing options...
Guest KRYSS Posted October 27, 2009 Share Posted October 27, 2009 chris what do you want for the pump oil kryss Quote Link to comment Share on other sites More sharing options...
Chris Posted October 27, 2009 Share Posted October 27, 2009 Ive pm'd ya mate, save hogging 4 posts lol Quote Link to comment Share on other sites More sharing options...
Guest rsturbz Posted November 7, 2009 Share Posted November 7, 2009 HI TO ALL THANKS FOR THE INFO HELPED A TREAT I USED BRAKE FLUID TO TOP UP AND THE ROOF WORKS PERFECTLEY JUST WANATED TO KNOW IF ANY 1 NEEDS PARTS I DO HAVE A 87 D REG CABI I AM STRIPING AS I GOT FED UP HAD A ELECTRICAL PROBLEM SO I DECIDED TO SSTRIP HER Quote Link to comment Share on other sites More sharing options...
allblue Posted November 26, 2009 Share Posted November 26, 2009 Would NOT recommend using brake fluid,if anyone is attempting this. It may work, but brake fluid is corrosive unlike the mineral oil that the pump actually requires. Not sure what damage this could cause to the internal plastic componments of the system over time. Also if the stuff leaks it will eat away your paint. Not too mention potential hazards with regards to future changes to the hydraulic system, as brake fluid is highly toxic. Pop down to your VW or Ford dealer and ask for the correct fluid for the pump, should set you back no more than a tenner. Quote Link to comment Share on other sites More sharing options...
