Guest thegod2k2 Posted July 27, 2009 Share Posted July 27, 2009 Hi sorry to be anoying, how the hell do you fit the speedo cable on this car its so tight, could someone show my where im going wrong please. Many Thanks Kev Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 27, 2009 Share Posted July 27, 2009 hi, have you got the correct cable? get the clocks out, connect that end 1st then feed gearbox end through the bulkhead and around the back of the engine, if you connect the gearbox end up 1st you end up scuffing ur arms too fu*k trying to get behind the clocks, hope this helps. Quote Link to comment Share on other sites More sharing options...
Guest Ady Posted July 27, 2009 Share Posted July 27, 2009 hi, have you got the correct cable? get the clocks out, connect that end 1st then feed gearbox end through the bulkhead and around the back of the engine, if you connect the gearbox end up 1st you end up scuffing ur arms too fu*k trying to get behind the clocks, hope this helps. AS I DID N GOT MAD :throw: Quote Link to comment Share on other sites More sharing options...
