Admin Ollie Posted May 16, 2009 Admin Share Posted May 16, 2009 hello peeps can the k jetronic unit be adjusted fuel mixture as it seems to be over fueling and soaking the plugs thanks in advance ollie Link to comment Share on other sites More sharing options...
Guest hagondaz Posted May 16, 2009 Share Posted May 16, 2009 hey i've done this to mine for the same reason, it's a allen key bolt a very long way down beneath a blue circle cap just behind the 4 fuel lines. the allen key will need to reach down a good 40-50mm and don't have the ignition on as you may get a slight shock i believe it's anti-clockwise to increase the fuel and clockwise to close it, BUT a very little adjustment can be a big difference, i let it run a little wile before i made the next small turn to make sure it's ticking over okay and it worked well. hope it helps, don't get carried away. Link to comment Share on other sites More sharing options...
Guest Eggsy Posted May 16, 2009 Share Posted May 16, 2009 as above - theres a little allen key bolt on the metering head - have a fiddle with that, just make sure it dont go to lean m8 Link to comment Share on other sites More sharing options...
Guest hagondaz Posted May 16, 2009 Share Posted May 16, 2009 a little tweak is a big difference too just stressing that, good luck Link to comment Share on other sites More sharing options...
Guest nickscunny Posted May 17, 2009 Share Posted May 17, 2009 To be honest Ollie I would get it set up on a rolling road. Like HagonDaz mentioned above, the littlest tweaks have a huge difference. So it needs a little at a time whilst running on the road..... Link to comment Share on other sites More sharing options...
Guest Eggsy Posted May 18, 2009 Share Posted May 18, 2009 to be honest Ollie theres no need for the expense of a rolling road really a simple crypton tune with lambda would be enough, & the best of it is that there should be somebody by you that'll do it mobile! Link to comment Share on other sites More sharing options...
Admin Ollie Posted May 20, 2009 Author Admin Share Posted May 20, 2009 thanks peeps i changed the whole k jettronic system over and was running but now i have found out the head gasket has gone stripped it back down again now ready to be skimmed ollie :throw: Link to comment Share on other sites More sharing options...
