Admin Ollie Posted May 12, 2009 Admin Share Posted May 12, 2009 hi guys need some help please as i am hitting a brick wall lol as some may no i have a se cab and want to fit the rs1600i engine and gearbox with ignition module (ecu) coil packs etc . before i started the project i was told it was an easy conversion . i have since taken the coil packs off and the rs1600 loom out because could not get the fuel pump working so i put the origanel standard loom back in and put a dizzy on and had the car running . what i need to no is can i still use the 16i loom and pink fuel pump relay to run the coilpacks and computer (ecu) i have not got the rs1600i clocks with the fuel shut off lights. normal 16i clocks the wires i have off the ecu computer loom are brown earth w/blue overrun fuel cut of valve (where would this go) blue which should go to the fused relay 31b/1 that i have not got in the 16i loom black should go to 87 in the fuse box relay v white not sure brown temp switch grey not sure it is doing my head in now lol :taz: if it aint running in the next few weeks the original engine and box is going back in lol thanks in advance for any help or advice i no most will say why bother but it is something that i wanna do thanks ollie Link to comment Share on other sites More sharing options...
Guest Andy Posted May 12, 2009 Share Posted May 12, 2009 stick with it pal Link to comment Share on other sites More sharing options...
Admin Ollie Posted May 12, 2009 Author Admin Share Posted May 12, 2009 stick with it pal i am trying lol need to find someone who has put the rsi engine in a xri or cab Link to comment Share on other sites More sharing options...
