Guest gazzoouk Posted June 12, 2008 Share Posted June 12, 2008 Firstly hello to everyone. I am new to this forum and i must say i have been impressed with what i have seen so far. I have just purchased a Mk6 Escort cabby and i love it apart from two annoying problems; 1. The heater fan does not work at all. I have checked the fuse and all is well, any pointers as to what to check next? 2. Drivers side rear quarter glass does not operate from either drivers switch panel or rear passenger switch. All other windows work and again fuse is good. Any ideas? thanks Gaz Link to comment Share on other sites More sharing options...
Guest cabbydaz Posted June 12, 2008 Share Posted June 12, 2008 welcome mate i would say the fan motor blown or wire cum of on the motor have look inside the engine bay where the motor is and check and the window motor sounds like its blown too very common in both iv got a spare fan motor if u need 1 or pop yor local scrapy Link to comment Share on other sites More sharing options...
Vincygav Posted June 14, 2008 Share Posted June 14, 2008 As above,check out your blower motor resistor block or the dashboard switch. Link to comment Share on other sites More sharing options...
chaz Posted June 14, 2008 Share Posted June 14, 2008 Welcome to cabbyland mate, hope you fix your cab soon so you can fully enjoy it. Link to comment Share on other sites More sharing options...
Guest gazzoouk Posted July 6, 2008 Share Posted July 6, 2008 Update, i took the fuse box out (quite simple) and carefully removed the printed circuit board. I then re-soldered all the component connections i could easily get at. I did notice than the copper tracks running to the blower fuse had got slightly brown in colour. I re-fitted the fuse box and hey pressto the blower now works so it looks like a dry joint was the problem. I am still trying to work out the issue with the rear quarter window. I brought a second-hand motor and plugged it into the connector but it did not work. I am assuming that i am not getting power for some reason. Gaz Link to comment Share on other sites More sharing options...
Guest marcus Posted July 6, 2008 Share Posted July 6, 2008 Update, i took the fuse box out (quite simple) and carefully removed the printed circuit board. I then re-soldered all the component connections i could easily get at. I did notice than the copper tracks running to the blower fuse had got slightly brown in colour. I re-fitted the fuse box and hey pressto the blower now works so it looks like a dry joint was the problem. I am still trying to work out the issue with the rear quarter window. I brought a second-hand motor and plugged it into the connector but it did not work. I am assuming that i am not getting power for some reason. Gaz [/quot Or the earth for the motor. Steve. Link to comment Share on other sites More sharing options...
Guest eddie Posted July 6, 2008 Share Posted July 6, 2008 hello mate and welcome to the club your best bet to save time and money with the rear window not working is to pull the connector of and test all the wires with an electrical meter tester to see if they are all doing what there supposed to because it sounds to me like you either got a bad earth or a broken wire mate hope this helps thanks eddie. Link to comment Share on other sites More sharing options...
Guest billena Posted July 8, 2008 Share Posted July 8, 2008 hi ya yes i had same problem with mk5 but both front windows/wipers/indicaters/fan all stoped working.. striped the fuse box box and yes i all so found 2 dry spots... seems to be a common prob... :convertible_mazeguy: Link to comment Share on other sites More sharing options...
