Guest spaceman Posted May 6, 2008 Share Posted May 6, 2008 Got one to change for MOT, never done it before. Looked at Haynes manual which was interesting. Is this a hard job? Not worried about stripping hub off as done that before but not sure about getting old bearings out and new in. Thanks Link to comment Share on other sites More sharing options...
Guest edy Posted May 21, 2008 Share Posted May 21, 2008 are you sure you have to change it, because if it is just movemnet you can just tighten the hub nut up to take the play out (dont get me wrong they will need changing) but should get you through the MOT Link to comment Share on other sites More sharing options...
Admin Paul Posted May 21, 2008 Admin Share Posted May 21, 2008 If its the front ones they will need replacing, only the rear one will tighten with the hub nut Link to comment Share on other sites More sharing options...
ianxr3i Posted May 21, 2008 Share Posted May 21, 2008 There not to bad a job to do. I work at fords & I can change a pair (both sides) in just over 3 hours from wheel off to wheel on. Link to comment Share on other sites More sharing options...
Guest marcus Posted May 21, 2008 Share Posted May 21, 2008 Thats why people dont go to main agents as much as they used to, 3 and a bit hrs@ about 75 quid per hour plus bearings at fords prices......lol you have just got a bill for over 300 quid. 40 mins a side job done at 35 per hour thats about 60 quid plus the bearing know where ill be going No wonder so many main agents are biting the dust Steve. Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted May 21, 2008 Share Posted May 21, 2008 Thats why people dont go to main agents as much as they used to, 3 and a bit hrs@ about 75 quid per hour plus bearings at fords prices......lol you have just got a bill for over 300 quid. 40 mins a side job done at 35 per hour thats about 60 quid plus the bearing know where ill be going No wonder so many main agents are biting the dust Steve. so true steve, 3 hours pmsl.... i can do it in less then that on the ground with only hand tools ....... was only chating about main agent prices tonight lol Link to comment Share on other sites More sharing options...
Guest sjc Posted May 22, 2008 Share Posted May 22, 2008 i tried it once....after 3 hours I stuck a load of grease in and gave up.....didnt even attempt the other one.....had to drill and retap the bolt hole for the disk as the original was rusted in there...a proper pain in the arse. If everythings been off recently and loose and nice and clean then maybe...if its old and rusting and youve not done it before, and are trying to follow haynes then its a shit job imho. still got a pair of front wheel bearings in me ever growing collection of bits that aint going on the car pmsl Link to comment Share on other sites More sharing options...
Guest steelcabby Posted June 1, 2008 Share Posted June 1, 2008 its not too bad a job, you just have to be careful not to damage anything when taken the bearing casing out, get the proper tool for it and make it easy for your self, else your be there with pushes and chisles and god know what else getting yourself stressed. i can do it fairly quickly now after doing it a couple of times. but for your first time i would say 2 hours a side, as your need to take your time and look it over before u commit to it.....got a vice? Link to comment Share on other sites More sharing options...
Guest Papa-D Posted June 1, 2008 Share Posted June 1, 2008 The best bet when you get the hub off the bearings themselves should just slide out no probs unless they are totally f*****d, its the casings that can be a pain to remove and replace. If you look at them first and they aint damaged and look like the new ones, you could just grease up the new bearings and chuck it back on in no time at all. But any scratches, rust, etc on the seats and they will have to come out. Link to comment Share on other sites More sharing options...
Guest steelcabby Posted June 1, 2008 Share Posted June 1, 2008 i would change the lot, but you probably already have by now. you can't always tell if the casing is that worn anyway. and if there is play in there then i would say they are shot. just make sure you don't damage by burring up edges etc when you tap them out, or you will have problems in the future Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted June 1, 2008 Share Posted June 1, 2008 How easy was it mate? Link to comment Share on other sites More sharing options...
