chaz Posted January 19, 2008 Share Posted January 19, 2008 Some of you will know that I have been looking for a replacement rear right hand side light on my mk3. Finally I managed to find one locally and replaced it today, after I put it all back and probably was like this before and did not notice it. The light bulb that is used as a brake light and side lamp lights real bright when the side lamp is on and goes dim when the foot brake is depressed so really its working the other way round. the left hand side works correctly. What can be causing this, is this an earth problem? Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted January 20, 2008 Share Posted January 20, 2008 sorry to hear you still have problems .... ok try the bulb again but turn 180 degrease .... if not then as you said try a exstr earth forn the light unit to chassie ...... normaly when a earth is not 100% the sidelight dimly flashes with the indicators ....... i probly havent helped but ..... hope it dose pmsl Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted January 20, 2008 Share Posted January 20, 2008 Sound just like the bulbs in the wrong way mate, done it a few times myself lol !!! Link to comment Share on other sites More sharing options...
chaz Posted January 20, 2008 Author Share Posted January 20, 2008 I did take the bulb out and cleaned it because it was very dusty, but I did not realise you can put it in the wrong way round, I mean its not marked in any way. Still I will try again. THANKS. Link to comment Share on other sites More sharing options...
